F@HMon ETA*Hung*
Discussion in 'bit-tech Folding Team' started by Bork_Bork, 28 Apr 2009.
  1. Bork_Bork
    Bork_Bork What's a Dremel?
    26 Apr 2009
    Found this explanation about clock synch on google:
    http://foldingforum.org/viewtopic.php?f=14&t=2139
    I run 2 SMP clients in terminals on another desktop, the time on the terminal seems to be 1 hour slower?
    I'm sure i's something simple but I'm off to work now so haven't go time to look into it.
  2. uncle_fungus
    uncle_fungus P/T Folding@home developer
    27 Mar 2009
    The time logged by the Folding@home client is *always* in UTC. Thus if you are in the UK and therefore in BST, the logged time will always be behind by 1 hour.
    In FahMon's preferences dialog, you need to make sure that the timezone is set correctly as an offset from UTC. Unfortunately there is a bug in the underlying library code that means automatic timezone detection isn't reliable and tends to break very badly.
    Assuming your clocks are then reasonably in sync the *Hung* status will disappear.
