Hi all, Am currently in the process of installing my EK waterblock for my GTX 570. Am preparing to cut up the thermal pads for the ram chips etc, however there are 2 different thermal pads supplied - one is slightly thicker than the other. Instructions don't mention 2 different pads Not sure which one to use - I am guessing that if there isn't sufficient contact using the thinner pad then reapply with the thicker one where contact is a problem. Can anyone who has already fitted one of these confirm this please? Don't want to get this wrong! Cheers! EDIT: Sorted - RTFM properly
Can you not tell by the quantity of the pads. e.g. if there is lots of small pads then there probably for the graphics cards RAM, or if theres only a couple of large pads then they'll be for the processor/s.
