Storage Rubber HDD Skins
Discussion in 'Hardware' started by NaNeil, 2 Aug 2009.
  1. NaNeil
    NaNeil What's a Dremel?
    27 Jul 2007
    Hey guys,
    So, my mobo came with a backplate for external sata power, and esata connectors... I have an old 3.5" SATA hdd that I use for backups, but due to the space limitations of my mATX case I'd like it to be external.
    As I don't need any convertors or fancy connectors as everything is passed through, I literally need a box to put the drive in.
    http://www.performance-pcs.com/catalog/index.php?main_page=product_info&products_id=20609
    These rubber skins are ideal, and only $3 (compared to ~£50 for a box that converts it to USB which I don't even need), but the only places I can find online are from the USA...
    Has anyone seen these anywhere in the uk at all?! Thanks!
  2. NaNeil
    27 Jul 2007
  3. Elton
    23 Jan 2009
    For some reason I wanted to tell you to put a metal weight on it...
    Although that would most likely be extremely unsafe.
    You could always get those CD changer rubber pads(the ones used to suspend the CD player) and put those to mount your HDDs.
