CPU Folding issues
Discussion in 'bit-tech Folding Team' started by steveneedle, 12 Nov 2013.
  1. steveneedle
    steveneedle Minimodder
    2 Jan 2010
    hi guys..
    wondering if anyone having the same probs as me
    running my i7 2600k 24/7 at stock speed
    it downloads a unit an in first say 1hr it says will finish in like 8hr...
    then after a few hrs that changes to like more than 1.5 days...to 3 days
    ive tried deleting the unit to download a new one but it is still the same
    this is also affecting the performance of my 480gtx
    the unit at the moment is a 8583...an its now saying 2.9days
  2. DocJonz
    DocJonz Another CPC refugee .....
    24 Apr 2009
    Do you have anything else running that is competing for the PC's resources?
  3. steveneedle
    2 Jan 2010
    no...ive got the antivirus to run in the night...
    its just the cpu an gpu folding
  4. steveneedle
    2 Jan 2010
    ive turned off my comp as its been running 24/7...
    now the new unit its on 8570.....
    it reckons my cpu will be doing just over 15000ppd....
    is that about right for an i7 doing that unit??
  5. steveneedle
    2 Jan 2010
    any ideas what a i7 2600k should do ppd?
  6. TaRkA DaHl
    TaRkA DaHl Modder
    15 Mar 2011
    Really varies with units, could be as low as 15k and as high as 30-32k.
    Does task manager show all cores/threads being used 100%?
    Have you left one free thread on the CPU to allow the GFX card to fold as well? As Nvidia cards need one thread/core to keep them stable.
  7. steveneedle
    2 Jan 2010
    at the moment it says the cpu is doint 17k...that's running 24/7...at 4.4ghz...6 cores
    I changed it so it was 6 cores running sso the gpu had more...
    480gtx is running just over 15k...
    I didn't know how many cores I should leve for gpu...that's why I put it to 6 cores
  8. DocJonz
    24 Apr 2009
    An nVidia GPU requires 1 CPU core to allow it to 'do its thing'. You can run without allocating it a core, put the GPU PPD will be lower - with high end cards, this has a big impact on PPD.
    Six cores is probably a good number to set it at, because there have been issues with people setting the number of CPU's to a prime number, e.g. 7, in the past. Stick to 6, and then you've future-proofed for adding another GPU :D
  9. steveneedle
    2 Jan 2010
    well ive been running my cpu with 6 cores now....an the cpu is getting about 15k ppd....is that about right?
  10. Scorpuk
    Scorpuk Minimodder
    10 Jan 2012
    Have you tried running with just the cpu and 8 threads to see what wu's you get and the ppd's?
    I am running my i7-2600k at about 4GHz, lol cant remember what I set it to now, and getting approx. 30k ppd. Running on ubuntu 12.04 and client v6. Not sure that should make a major difference these days.
    Currently running: TPF: 00:06:50 / PPD: 31942.3 / WU: P8557 (R1, C4, G79)
    Maybe not worth the electricity to run the GPU if you can get 30k with just the cpu.
  11. steveneedle
    2 Jan 2010
    hi
    sorry for the delay
    just going to try running just the cpu an see what I get
