Blogs Is 2014 the year that 4K goes mainstream?
Discussion in 'Article Discussion' started by Meanmotion, 6 Mar 2014.
  1. Meanmotion
    Meanmotion bleh Moderator
    16 Nov 2003
  2. David
    7 Apr 2009
    I can appreciate the idea of a 30"+ 4K monitor but, surely, 4k on a 24" screen is only providing half the benefit. Games and movies will be gloriously pin sharp, but the icons and text will be so small many people will have to rescale the default sizes to use it comfortably, thereby largely negating the extra screen real estate 4K resolution affords.
    Or am I wrong?
    G0UDG likes this.
  3. GeorgeK
    18 Sep 2010
    I think it'll be a while yet - you're looking at a massive (£1000+) outlay if you want a 4K monitor and the GPU power required to game at that resolution with all the eye candy turned up - 780ti SLI wouldn't do that for BF4, Crysis 3 etc and you'd be looking at just shy of 2 grand for a monitor and two of those...
  4. Guest-16
    Guest-16 Guest
    700 quid for 27-28 inches, George. TN for now, next year probably eIPS equivalent.
  5. Pete J
    Pete J Employed scum
    28 Sep 2009
    4K is awesome.
    However, games developers need to catch up on the texture resolution front. Mass Effect 3 with community hi res textures is sublime to behold on a 4K monitor.
  6. Guinevere
    Guinevere Mega Mom
    8 May 2010
    Mostly...
    On a Mac, HiDPI screens are handled extremely well. For example a 2880x1800 screen will provide an optimal working resolution of 1440x900, which uses a 2:1 ratio. Everything is pin sharp but text and icons are the same size as on a 1440x900 screen.
    Different 'resolutions' can be used EG 1920x1200 but then you're breaking the magic 2:1 ratio so while images look sharper than they would do otherwise it's not perfect.
    But you're always getting extra detail from those extra pixels. Even if icons and text are the same size and you have no extra working room you still get a much clearer display.
    Is 4K needed at small sizes? No more than 'retina' displays are needed on mobile devices. You don't get any more icons on the screen but the screen looks so pretty :)
  7. Bokonist
    Bokonist What's a Dremel?
    2 Mar 2011
    In accordance with Betteridges Law of Headlines:
    No.
    Tyinsar likes this.
  8. David
    7 Apr 2009
    That's what I said - it'll look pretty but you don't get the benefit of extra desktop space that 4K can provide.
    G0UDG likes this.
  9. Guinevere
    Guinevere Mega Mom
    8 May 2010
    Yes, but 4K can either give extra desktop space on huge screens, or a crisper display at smaller screen sizes. Or a bit of both.
    Having larger and smaller 4K screens is brilliant! We can finally choose the monitor that's right for us and the Popular OSs are good enough to allow us to select between crispness and/or screen real-estat, or to find the perfect balance.
    It's not an either/or choice, it's how much of each do you want at this exact moment in time. You can switch easily and quickly these days. On my retina I will switch between 1440x900 & 1920x1200 resolutions depending on what I'm doing and when at the desk it's 1440x900 + 1200x1920 + 2560x1440
    It's "You don't need that resolution at that screen size" thinking that allowed manufacturers to think a 1080p display was fine for a 27" computer monitor.
  10. GeorgeK
    18 Sep 2010
    My numbers included the necessary GPU upgrades to make games work / look pretty
  11. matee
    matee What's a Dremel?
    12 Feb 2003
    My thoughts exactly. I would make a jump, but I'm sure my good old GTX680 will not handle it. there is no point upgrading the monitor and scale back on textures, AA or resolution.
    Sure its different for graphic designers, but as a gamer I'm not making a jump just yet.
  12. Maki role
    Maki role Dale you're on a roll... Lover of bit-tech
    9 Jan 2012
    To be fair, upping the resolution so considerably would allow you to reduce the amount of AA being used in the first place. People don't often seem to take that into account when discussing the performance hit of 4K gaming.
  13. GeorgeK
    18 Sep 2010
    True, although if you look here you can see that two 780TIs can only manage 40fps on BF4 on ultra even with 2xMSAA only... 4K is roughly 8.3 million pixels compared to less than half that (4.1 million pixels) with 2560x1600
  14. Cei
    Cei pew pew pew
    22 Mar 2008
    Actually, there's another level with Apple's handling of HiDPI.
    If you're running in "retina mode" (ie: looks like 1440x900), but start an enabled app, the screen starts doing funky things. Aperture is Apple's version of Lightroom (photo editing software), and it will run the UI at the 1440x900-alike scaling, but the actual images will be displayed at native panel resolution. So, for the UI where you don't want things teeny tiny you get everything readable, but for images where you want as close as to 1:1 pixel mapping as possible, you get the full 2880x1800 resolution. It's glorious, and they do the same for Final Cut Pro and other such software.
    It makes Microsoft look like idiots. I don't understand how Windows' HiDPI handling is so bad - 4K hasn't exactly been a secret, and they've had plenty of time to sort it out, but they seem to have stuck their fingers in their ears.
    I for one welcome our 4K overlords, but only when they stop the 30Hz nonsense in cheap panels and GPUs catch up. Sure you can drop AA, but you still need two high end cards at the moment to make headway. I'll go 4K in 2015/16 probably.
  15. Combatus
    16 Feb 2009
    Precisely. I've got a 21in 1080p display in front of me now as a second monitor and it's much sharper than the 24in 1,920 x 1,200 Dell U2412M sitting next to it. For me it's not the extra desktop realestate - it's the extra sharpness that's the real boon.
    However, it's good to see something other than game graphics driving forward the need for faster hardware - resolutions look set to increase significantly as these new screens come in to play so it will be interesting to see how AMD and Nvidia deal with it - after all, just because you have a few hundred pounds to spend on a monitor, doesn't mean you can also afford two GTX 780 Ti's :D
  16. Anfield
    Anfield Multimodder
    15 Jan 2010
    4K monitors going mainstream in 2014? I fear they won't be mainstream until 2016.
    Not only will they be much cheaper then, but also if we are lucky one gpu will be enough.
  17. Dogbert666
    Dogbert666 *Fewer Lover of bit-tech Administrator
    17 Jan 2010
    This is true, even on our 31.5-inch 4K panel, it's almost impossible to notice a lack of AA (we test at 4K with AA disabled for this reason). On an even smaller screen I don't think you'd see it at all, and it certainly wouldn't make a big enough difference to warrant the performance hit. But it is also true that it will cost you *a lot* of money to get GPU hardware capable of running games maxed out at 4K.
  18. Guinevere
    Guinevere Mega Mom
    8 May 2010
    Isn't that what I said? Lightroom was updated ages ago too. Can't remember the last time I saw an app that wasn't HiDPI aware.
    Apple still aren't there either with 4K panels, not with anything other than their latest and greatest machines... and only then with certain panels.
    It's not always a hardware issue, if you're willing to jump through a lot of hoops you can get 4K nicely on OSX across a wider variety of hardware.
    Everything will get better though.
  19. Cei
    Cei pew pew pew
    22 Mar 2008
    Nope, that's not what you said (I think?). You explained the 2:1 ratio, and that you can also select other resolutions, but not the mode that essentially runs both resolutions at the same time.
    HiDPI aware for many apps simply means they have high resolution artwork, and can handle the 2:1 scaling without looking nasty. Adobe and Apple are amongst the few that have taken HiDPI and run with it to allow UI/font scaling at the same time as retaining the native panel resolution for imagery. But only on OS X.
    UI scaling example, when app is aware or not. But this is simply font scaling and images being updated with higher resolution versions suitable for pixel doubling.
    http://forums.adobe.com/thread/1323412
    This thread on Adobe's forums shows the problem they're having with Windows. Microsoft just haven't got the core software in place - Adobe can't commit to a timescale for a fix, and "Microsoft is getting closer, but isn't there just yet".
    Hardware is a different thing entirely. I'm expecting Apple to release a 4K update to their display, but when is another question entirely. However you can use any 4K screen on the market, so aren't just restricted to Apple.
  20. jrs77
    jrs77 Modder
    17 Feb 2006
    4k becomes mainstream, if the prices of these become mainstream. Simple as that.
    Start selling 24"-screens with a 4k IPS-panel for ~€600 and we can start calling it mainstream.
    GPUs to power these screens are not a problem, aslong as we don't talk about playing games @4k-resolutions.
    Hell... even a €400 iPad has more pixels than a 1080p Display, so just start building such panels in larger sizes and quantities.
Tags: Add Tags
