Headless Linux V7 Guide
Discussion in 'bit-tech Folding Team' started by Votick, 17 Mar 2014.
  1. Votick
    Votick My CPU's hot but my core runs cold.
    21 May 2009
    Anyone got a good one to follow?
    I have some CPU's to fold on.
    The onld V6 client seems to not work.
    Even if I give it the a3 core it trys to re-download it and then can't download it.
  2. DocJonz
    DocJonz Another CPC refugee .....
    24 Apr 2009
    There are pre-requisites for the v6 Linux client - 'ia32-libs' if I recall. Try the v7 client - works fine on Linux.
  3. Votick
    21 May 2009
    Got V7 installed and working.
    However I've got no control over it.
    In the config.xml the remote section has sotmhing like
    127.0.0.1 X.X.X.X
    What would I need to set to allow all IP's and then a pass to auth.
  4. DocJonz
    24 Apr 2009
    Did you install both parts of v7 for Linux, i.e. FAHclient and FAHControl?
    FAHControl, as well as allowing control for the clients in general, also allows setting of the remote access.
  5. Votick
    21 May 2009
    Yes, both parts.
  6. Scorpuk
    Scorpuk Minimodder
    10 Jan 2012
    So I dont need to faff around I installed vncserver on my headless and use vnc to take control. :)
    I followed most of this guide to install vnc server with a classic gnome frontend: http://rbgeek.wordpress.com/2012/06/25/how-to-install-vnc-server-on-ubuntu-server-12-04/
    I then use ssh to run the vncserver when I want and give it dimensions:
    Code:
    vncserver -geometry 1280x1024
    F@HControl will be under a Science tab on the menu.
    Letting you have normal control over F@H. :rolleyes:
    For external access I only run vncserver when I need to and I port forward on some random ports to try and stop access from anyone else. :lol:
  7. Votick
    21 May 2009
    Was going to do that but my xstartup never works.
    I ether get a desktop with a mouse on it.
    No menu.
    Black & white hashed screen
    Or a grey screen with a few tick boxes on.
  8. Scorpuk
    Scorpuk Minimodder
    10 Jan 2012
    The box in the image above has only ever had a monitor attached to it when I initially installed ubuntu. Its had a few reboots in its time and not had a monitor attached during those either and can still run vncserver.
    Did you install the full desktop version and if so which version?
  9. Votick
    21 May 2009
    It was running Latest version of Ubuntu server.
    I installed gnome-desktop.
    EDIT: Looking at my sig it seems it's folding away so might not bother with the control.
  10. Votick
    21 May 2009
    Back in the red.
    Steady 10K going.
    Will likely ramp up some more once I've sorted a few systems.
