FuG-01/ET - mod finnished, some new pictures
Discussion in 'Project Logs' started by Sheyr, 6 Apr 2005.
  1. Sheyr
    Sheyr What's a Dremel?
    3 Mar 2005
    Hi everybody!
    I finnished the case. I hope you will like it. Everything works well. The voltmeter indicates the critical voltages 3,3V, 5V and 12V and the fan voltages (case fan, CPU fan and PSU fan). The ampermeter indicates the total current consumption. Below you can find the complete worklog
  2. tm36usa
    tm36usa What's a Dremel?
    21 Jan 2004
    Ok First off, WELCOME TO THE FORUMS!!!
    on another note, and because you new you didnt know, this should have been posted in the modding section. The project logs is for mods with pics and modding. Again, just letting you know, no ones mad but everyone must learn.
    On a modding related not, you idea sounds really cool and I like the name too. Best of luck to you!
  3. Sheyr
    3 Mar 2005
    hmmm...... i think i can not insert images ... :confused:
    can anyone hepl me pls?
  4. Sheyr
    3 Mar 2005
    thanks tm36usa, that's what I'm really going to do - i've already started the job and i'm giong to insert some images , but it seams to me that this function is disabled for new users?
  5. tm36usa
    21 Jan 2004
    Weird about the images.. Cheat the system, put this - "[​IMG]" again with out the quotes. Hope this helped you.
    Oh are the images hosted? or are they on you computer?
  6. Sheyr
    3 Mar 2005
    for my mod I used a standard used Compaq miditower case
    (trying to insert first picture....)
  7. Sheyr
    3 Mar 2005
    pictures are working :D
    so the 2nd view of my Compaq - a 1mm steal , very hard to cut and drill !!
  8. Sheyr
    3 Mar 2005
    After some first ideas i decided to cut out a crow in the side cover
    so I've prepared a template
  9. Sheyr
    3 Mar 2005
    this is a crow on a side cover
  10. Sheyr
    3 Mar 2005
    the 2nd template is used to cut out the hole
  11. Sheyr
    3 Mar 2005
    but before the crow-hole is done I drilled holes for rivets
    (sory about my English!!)
  12. Sheyr
    3 Mar 2005
    unfortunately that's all for today. Next updates on weekend I hope.
  13. dubya01
    dubya01 What's a Dremel?
    22 May 2004
    wow thats gonna be alot of rivets
  14. tm36usa
    21 Jan 2004
    Looking Great!! :thumb: Just a tip but you should make a entire update 1 post, not a post for each picture.
  15. Axly
    Axly slo-mo...dder
    7 Nov 2003
    Nice idea, and I'm looking forward to seeing the birdie once it's riveted.
    I'm not sure the WWII Germans would be very happy when you call the two headed "Kaiseradler" (Emperor Eagle) a crow ;)
  16. Blackfish23
    Blackfish23 Minimodder
    13 Oct 2004
    looking good :thumb:
    Looking forward to see where this one goes
  17. Sheyr
    3 Mar 2005
    Yes, you're right Axly - thanks for the remark. In fact I didn't know what kind of bird it was :confused: I'd like to say sorry to the German colleagues!
  18. Sheyr
    3 Mar 2005
    And now some of today's work
    the hole
    and the EAGLE :) in the begining of cutting out
    and after cutting out
    And that's all for today.
  19. Pitbull
    Pitbull What's a Dremel?
    20 Mar 2005
    funny looks :hehe:
  20. Sheyr
    3 Mar 2005
    Some updates of Monday's and Tuesday's work......
    drilled hols for rivets in the bird
    painted with a grey primer
    and with the red primer
    i also painted a part of case cover with the primer
    and with the first cover of green paint
    first look at the case with the eagle :D
