News Apple adds Force Touch to refreshed MacBook Pro family
Discussion in 'Article Discussion' started by Gareth Halfacree, 20 May 2015.
  1. Gareth Halfacree
    4 Dec 2007
  2. Jimbob
    Jimbob Minimodder
    2 Jul 2009
    Hang on M370X available today? Has the mobile 3xx been released or are these rebadged 2xx GPUs?
  3. Gareth Halfacree
    4 Dec 2007
    These are OEM-only parts, as per my write-up of the 7th of May.
  4. MrJay
    MrJay You are always where you want to be
    20 Sep 2008
    You'd think they would want to make it a standard port for all upcoming lines, so you know people who are invested in their ecosystem can use adaptors on multiple devices in the range.
    Even if they had implemented a Type C connector in addition to the standard Apple I/O.
    I don't get Apple... I really don't.
  5. SchizoFrog
    SchizoFrog What's a Dremel?
    5 May 2009
    As far as everything I've read is concerned, the majority of 3xx series GPUs are re-badged 2xx series which in turn were mainly re-badged 7xxx series GPUs. The only exception so far is the expected 390X with HBM.
    However, I am not sure how this all translates to the 'M' market...
  6. Cei
    Cei pew pew pew
    22 Mar 2008
    The MacBook Pro refresh is a minor spec bump - the CPUs are remaining Haswell, so it's literally a GPU change and the new touchpads. Apple will introduce USB-C when they actually update the design of the chassis, which is likely to be Skylake. A that point, expect the MBPs to lose a bit of thickness, drop their USB A ports and possibly even lose Thunderbolt, replacing them with some USB C ports.
    USB C is going to be Apple's standard port, no doubt. It'll just take 12-18 months to move the line over.
  7. SchizoFrog
    5 May 2009
    But... but... they won't be able to charge extortionate amounts of money for proprietary cables!! Then China's economy will crash as millions stop buying copy cables and adaptors. Oh my, you just predicted the end of the World...
    THE END OF THE WORLD!!!
  8. Atomic
    Atomic Gerwaff
    6 May 2002
    The only downside to USB-C is that it's used for charging, which means loosing the magsafe connectors which are such a good design.
  9. SchizoFrog
    5 May 2009
    Why does charging affect that? If they can be used as power cords then I don't see an issue.
  10. Atomic
    Atomic Gerwaff
    6 May 2002
    The magsafe connector does not plug into a socket, it is attached via a magnet. This is unique in that if the cord is pulled out it gracefully detaches rather than being yanked out of the socket like a normal connector.
    USB-C uses a traditional plug and socket and not a magnetic attachment.
    Magsafe is great, it will be a shame to see it go.
  11. SchizoFrog
    5 May 2009
    Hang on... Did you mean that Type-C is now going to be used to charge the MBP?
  12. Guinevere
    Guinevere Mega Mom
    8 May 2010
    It's already used for the macbook. It stands to reason they'll add it to the pro line.
    Would I be prepared to sacrifice losing magsafe if I gained the ability to charge via any decent USB charger? The type of charger I carry around anyway to quickly top up iPads and iPhones? Would I gain enough to easily top up my laptop from my USB battery packs? Or my USB in car sockets?
    Yeah, I probably would. Damn you Apple. You giveth and you taketh away.
  13. Cei
    Cei pew pew pew
    22 Mar 2008
    Yes, Apple will be switching to USB C to charge MBPs down the line. My new MacBook already charges over it's sole USB C port, with the huge thing that the power brick is the same size as the iPad one, not the behemoth that is my 85W MacBook Pro (retina) one.
    Yes, I'm sad to lose MagSafe, but it's incompatible with USB C. But there's definite benefits to USB C. MagSafe works because it's a very shallow connection, so when pulled out it detaches easily. USB C is deeper (imagine the port on an iPhone or iPad), so it isn't going to disconnect when yanked.
    I'm also amazed that Apple are ditching their profitable accessory market. They've already said that they're not releasing any new adapters beyond the current range of 3 (USB C to A, Digital Multiport and VGA Multiport). They're literally relying on third parties to fill the hole and provide consumers with hubs and other video adapters.
    85W Retina MacBook Pro vs 29W Retina MacBook power bricks:
    USB C vs MagSafe2:
    Yes, my MagSafe charger is a bit battered as it's my travel adapter. The USB C is brand new on the other hand.
  14. RedFlames
    23 Apr 2009
    Could they not just add the 'magsafe' bit further down the cable... a bit like the plug/socket on my wired xbox 360 pad. That plugs in via usb but a little ways down the cable there's another connection which is designed to come out should you trip on the cable.
  15. Cei
    Cei pew pew pew
    22 Mar 2008
    That'd ruin the the sleek cable though....
    So yes, they could, but they won't.
  16. RedFlames
    23 Apr 2009
    it doesn't have to be the same format that the current magsafe is in, but as you said, if they could have they would have...
    Just seems lazy and short-sighted to me...
