Bit new to this but I am trying to render a zoomed out view of my building but everything I do results in a zoomed in picture of a small part of it. Any advice on how to get it to zoom out??
You need to zoom out in Indigo, not in SketchUp. SketchUp by default saves the current point of view along with the model so that when you next open the file in SketchUp, you are at the same point of view as you left off. But when you open the SketchUp model in Indigo, you are basically just importing the model. Indigo has its own camera, hence its own point of view, so to speak.
I am using the SKindigo plugin btw in case that changes things. I am not sure I understand I zoom out but the image does not change, previously when I moved the camera in sketchup it did so in indigo so I presume I have changed a setting somewhere.
Perhaps the zoom control is for the user's convenience (detail work) but does not relate to the camera as such?
