SketchUp Raspberry Pi stackable case
Discussion in 'Modding' started by Rhydian, 26 Jan 2012.
  1. Rhydian
    Rhydian What's a Dremel?
    13 Nov 2010
    This is a case concept in the works. It involves a aluminium case a few mm's larger then the raspberry pi unit.
    I've included venting holes into the design to allow heat to dissipate. I'm unsure about what to do to hold the rpi down, perhaps using Neoprene sponge underneath and having side clips holding it firmly down.
    Any ways some screenshots. (also note this will be satin black brushed aluminium and purple acrylic with leds behind to glow.)
    can't wait to do this :dremel:
  2. Jake123456
    Jake123456 Surprise!
    25 Jan 2011
    Ahh, so you are going with the stack ;)
    Are you not going to try watercooling it either?
  3. Rhydian
    13 Nov 2010
    Too small :p
  4. Jake123456
    25 Jan 2011
    It might be worth getting a custom made water block, and like I said, have it arcing across the screws to the CPU and RAM, problem is where would the fan go..
    Just a quick question, as I'm having the same problem on mine, how did you hide the fact that the USB ports stick out like an eyesore?..
  5. Rhydian
    13 Nov 2010
    Made the case cover the largest connector so some parts might be deeper then others.
  6. Jake123456
    25 Jan 2011
    Ahhh, I may just put an extra 1mm on the front of it, so it covers the USB Port...
    Still using metal? Or going plastic?
  7. Rhydian
    13 Nov 2010
    metal all the way :D
  8. Jake123456
    25 Jan 2011
    Aha, plastic power for me ;)
    Going to keep this as cheap as possible, I want to play some Terraria goodness on it.
  9. Jake123456
    25 Jan 2011
    Also another thought Dweller, why not cover all the ports on the second one you're using to stack? Might look a bit neater?..
  10. Mojo
    Mojo Multimodder
    18 Nov 2011
    Pah... you arnt trying hard enough!
    if i can watercool a pico.. you can cool one of those ;)
  11. Rhydian
    13 Nov 2010
    Meh doesn't look good enough to make it neat lol
  12. Jake123456
    25 Jan 2011
    Have you seen my finished design? ;)
    I would blank them out..Unless you want to dual boot for some reason..
  13. Nexxo
    23 Oct 2001
    Water cooling would kind of defeat the purpose of having a cheap, low power compact platform.
  14. Jake123456
    25 Jan 2011
    But it would look pretty sweet wouldn't it? If you do have the money it would be worth it, but it would be pretty pointless as whats there to cool?..
  15. Rhydian
    13 Nov 2010
    A couple of copper pipes on top of the chip would prob do just aswell though jake :p
  16. Furball Zen
    Furball Zen Shut up and Mod
    25 Jan 2012
    This is something i could 'mass' produce with my laser cutter.
  17. Rhydian
    13 Nov 2010
    You can mass produce them if you want :p
  18. Nexxo
    23 Oct 2001
    It would look silly:
    Some beautiful mods could be made with passive copper heatsink arrays. Pretty and functional. That is what good design is all about.
