Thought that I had decided on the Raijintek Metis until I realised that the PSU was at the front and my memory of a case with similar PSU positioning was one of noise and got rid of it very quickly. Have now turned my attention to the Lian Li PC-V359 even though it is a lot more than I wanted to pay. Anyone had experience of this case? Or any other suggestions only one stipulation it cannot be black? I know I can paint but if I can find something without doing that, great. Edit: Sorry two stipulations must be windowed.
http://www.bit-tech.net/hardware/2012/09/06/bitfenix-prodigy-review/1 Available in red. Decent price also. £44 here for an Aqua Blue open box effort http://www.cclonline.com/product/19...i-ITX-Cube-Case-Aqua-Blue-Open-Box-/CAS1834X/
Thanks but I have had a prodigy before and not one to have the same case twice. But on saying that it is not actually my PC it is the general rig which we both use for searching, email and the like so might work.
This is a contender. https://www.overclockers.co.uk/phanteks-enthoo-evolv-micro-atx-case-white-ca-013-pt.html
Forgive my confusion (chemo brain) but which way is width, as in 260 x 320 x 397 (WxHxD mm)? https://www.scan.co.uk/products/corsair-carbide-series-air-240-high-airflow-micro-atx-pc-case-white
Referring to the picture on Scan it is 260 W x 320 H x 397 D Well look at that, we've both just blown straight by the 10,000 post barrier! Spam-tastic
I went through the barrier on Saturday. I celebrated the event. http://forums.bit-tech.net/showpost.php?p=4032593&postcount=27 But as to my question is width from side to side or front to back?
Just bought the Carbide.There is a 20% discount off Ebay Purchases till 10PM Tonight (31st)The code is CUK20. So saved myself 15 quid.
