Cooling Clearance issue with AIO cooler backplate
Discussion in 'Hardware' started by phinix, 21 Mar 2017.
  1. phinix
    phinix RIP Waynio...
    28 Apr 2006
    Guys, did you ever have problem with AIO coolerbackplate on mITX motherboards?
    My Silverstone TD03 Tundra have huge backplate and interfere with motherboard components in the back:(
    Its hard to explain without showing photos of this, but cooler backplate touches some electronic components on the back of the mobo. I tried to turn it 90 degree and install that way, but it still touches some of the bits.
    This is second mobo I found this problem with this same cooler.
    Did anyone have issues like that?
  2. Wakka
    Wakka Yo, eat this, ya?
    23 Feb 2017
    Can you use some plastic washers to act as stand-offs? Or even a small pad of neoprene/foam?
  3. phinix
    28 Apr 2006
    I think I'm gonna have to. Backplate is so wide with all the holes etc that it presses against mobo bits.
    here is photo I found of that plate, you can see who wide it is.
    On ITX mobos it HAS to interfere with something...
  4. Vault-Tec
    30 Aug 2015
    Surely that's supposed to have a rubber part the same shape?
  5. modd1uk
    modd1uk Multimodder
    4 Sep 2006
    Nope, i've had a few coolers like this that I've sent back as I didn't want to risk shorting something out.. :(
  6. phinix
    28 Apr 2006
    Nope, nothing there.
    There are plastic bits between metal plate and mobo, but those are pressing against some mobo elements, so this is worrying me..
    I haven't started this up yet, but thinking of putting some gromets or something like that....
