Guide Quick thread tapping question
Discussion in 'Modding' started by atc95, 30 Mar 2017.
  1. atc95
    atc95 I have the upgrade bug!
    3 Dec 2012
    Hi,
    I am planning on modding my case and am going to be mounting an xspc ion to either the side or roof of the case. The supplied screws are 2.8mm (UNC 6-32) but the supplied bracket has room for M3 screws with a nut to secure the pump in place if it were to be hanging from the roof of the case.
    I have read that the tap needs to be slightly smaller than the hole so what drill bit should I start with and what tap to make an M3 hole. At the moment I have a 2.8mm drill bit and M3 tap in my amazon basket but not sure if this is exactly what I need.
  2. ElThomsono
    ElThomsono Multimodder
    18 Mar 2005
    For an M3 tap, drill to 2.5mm.
  3. atc95
    3 Dec 2012
    Thank you.
  4. cobalt6700
    cobalt6700 Minimodder
    17 Oct 2005
    As a rule of thumb: if it's a standard metric pitch then take the off pitch valve from the thread size and that's your tapping drill :thumb:
