ok just ordered a load of stuff from aqua tuning was wondering if anyone knows where i can find pass through fittings for 11/8" tubing??? couldnt seem to find them on aquatuning need 3 in total so would be good if i could get a heads up where to get them from or if any1s got some cheers infiniti
It's linked direct to the water mains, can't get any cooler than that Try electrical suppliers they do grommets in all sorts of sizes.
11/8mm is slightly too big to use with 10/8mm bulkhead fittings as the barbs are usually compression type and may not fit under the locking ring. Your best bet would be to buy a G1/4 bulkhead fitting then you can use whatever barbs/tubing size you like.
