Displays U2410 still the king?
Discussion in 'Hardware' started by ModSquid, 29 Apr 2014.
  1. ModSquid
    ModSquid Multimodder
    16 Apr 2011
    Quick one, chaps - have done the research and the Dell U2410 still seems to be highly regarded, but am aware that it's knocking on a bit now.
    Anyone know if it's been usurped by a more recent monitor of similar or better quality?
    Cheers!
  2. GoodBytes
    20 Jan 2007
    Quality? I don't think so.
    However, IPS monitors got significantly lower input lag these days thanks to faster internals. And now you have IPS monitors without color processor and fancy things, mix with a really fast controller, allowing a near 0ms input lag, which is more attractive for gaming.
    You can also get higher resolutions like the Dell UP2414Q, a 24inch 4K 60Hz IPS monitor.
    The U2410 is quite old monitor now. It's still nice, as monitor technology does move slowly.
  3. donok
    donok Every Little Helps .....
    16 Feb 2011
    my u2711 is amazing but if i was getting a new monitor i would be looking at LG's ultrawide
  4. rainbowbridge
    rainbowbridge Minimodder
    26 Apr 2009
    lol, I have the LG ultra wide and I am looking at the u2711
  5. ModSquid
    16 Apr 2011
    Cheers guys. I should probably add that at the moment I'm looking at second hand or a budget of about £160, 24" or 27" and NOT 1080p ie. 1920x1200 minimum.
    I did check out that Dell UP2414Q (cheers goodbytes) but it was a bit too expensive and some of the reviews weren't great. I think I'll wait a bit for 4K to bed down before jumping on that one.
    Uses will be photo editing at a reasonably high level and gaming, hence my attraction to the U2410.
  6. CrapBag
    CrapBag Multimodder
    17 Jul 2008
  7. SuperHans123
    SuperHans123 Multimodder
    27 Dec 2013
  8. Jim
    Jim Ineptimodder
    2 Sep 2007
    Given your budget, I doubt you'll do much better than a U2410.
    My inclination would be the U2713HM (or is it U2714HM now?) or the UP2414Q but they're much more expensive - and the main benefit on those is a higher resolution.
    If you're happy with 1920*1200, then you'll probably be very happy with it. Most of the options in the market right now, certainly at this price range, are 1080p.
  9. Guinevere
    Guinevere Mega Mom
    8 May 2010
    I still use my 2410 daily. It's orientated in portrait and used with my Dell U2713HM and and Apple retina in my laptop. It's a nice screen and much better in portrait than a 1080p screen would be.
    This pic makes it look pink, but it's not in reality. This colour cast is just how my phone reacted to the backlight.
    Still has great colours, and warms up quick. But not being LED backlit it's a warm monitor (Warm, not hot). I had to swap it out due to a blue line glitch (google it) but you can have issues like that with any monitor so wouldn't put it down to an inherent problem.
  10. Jim
    Jim Ineptimodder
    2 Sep 2007
    Your U2713HM isn't in that photo... is it?
  11. julianmartin
    julianmartin resident cyborg.
    25 Jul 2004
    I too am very happy with my U2410. I'll probably get the dell 27" next though.
  12. ModSquid
    16 Apr 2011
    Cheers fellas - some food for thought there. Anyone know how the new U2413 stacks up against the U2410? I understand some of the tech has changed, like the backlight moving to LED.
  13. Teelzebub
    27 Nov 2009
    I've got a dell 24" and two 27" all are great monitors
  14. mucgoo
    mucgoo Minimodder
    9 Dec 2010
    Have look for a HP ZR24W as well. Not wide gamut but otherwise comparable to the 2410 and probably cheaper due to less brand appeal. I got one for a £100 and couldn't be happier.
