Case Mod - In Progress Project : Make it shine : Finished : 3/20/10
Discussion in 'Project Logs' started by The_Beast, 21 Feb 2010.
  1. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    No fancy banners or sponsors, just a project log, so I'll get right too it.
    My mission was to take this and make it shine (hence the name)
    The enclosure striped and naked
    My work space, everything was going to be hand sanded :sigh: :duh:
    Here it is after 60 grit, which in hind sight was too rough of grit
    After 120 grit
    The center part after 1000 grit, I'm thinking I'll have to redo the 320 grit on this because it isn't very uniform
    Since my arm was pretty much nub I decided to call it quits for the day. BTW I started at 2:30 pm and stopped at 10:00 pm
    And my workspace after
    Tomorrow's another day
  2. MugenUK
    MugenUK What's a Dremel?
    5 Aug 2008
    Interesting so far mate, will check back to see where this goes - starting with that case I've got high hopes!
  3. The_Beast
    21 Apr 2007
    No pics but I did make some head way in the sanding
    More work tomorrow
  4. grritsshawn
    grritsshawn I'm not insane I'm a modder
    20 Apr 2009
    nice work
  5. Cheapskate
    13 May 2007
    That's a lot of sanding. You may have the paper turned around the wrong way too.:D
  6. coolmiester
    coolmiester Coolermaster Legend
    31 Dec 2002
    Good luck with this one - i did it with a Wavemaster a while back which turned out great and contemplating doing it to an 840.
    Hard work though when you're doing it by hand as you're finding but keep at it as the results will be well worth it :eeek:
  7. The_Beast
    21 Apr 2007
    No, I'm sure I was sanding, I have the filthy water to prove it
    It will turn out, and if I can't get it polished just right I'll leave it at 2000 grit and make it look like the lian li super fine brushed finish
  8. The_Beast
    21 Apr 2007
    Starting out with rubbing compound, a microfiber and a good attitude
    After piss poor result of both hand polishing and the rubbing compound I decided to use Mother mag polish and a dremel (knock-off) with cotton tips
    I got dirty but also some really good results
    The pics speak for themselves
    Bling bling
    And my HDD back in it's happy, polished home
    If I'm not doing anything tomorrow I'll try to finish the outer case
  9. ringo
    ringo What's a Dremel?
    14 Jun 2008
    Nice and shiny hdd case.
  10. The_Beast
    21 Apr 2007
    Thanks
    I'll probably sand more tonight but no pics because they're kinda boring. I hope to have this project wrapped up by next weekend.
  11. The_Beast
    21 Apr 2007
    Sorry no pics (maybe later tonight) but everything is sanded down to 1000 grit on the outer case after 4 hours. This weekend should be all about polishing and getting this project wrapped up.
  12. The_Beast
    21 Apr 2007
    Another 4 hours today got me down to 1500 grit and a good start on 2000 grit. Tomorrow should warp up this project so I can start another one :thumb:
  13. The_Beast
    21 Apr 2007
    All done, time to clean up
    Another project done :hehe:
    Pics speak for themselves
    My room via the reflection
    Not a great pic but it show even the visible inside of the outer shell is polished
    It's desktop comrades
    My next project is to paint one of the other 2 enclosures flat black, see you in the next project log :dremel:
  14. Cheapskate
    13 May 2007
    I request that you turn the lights on and take another picture!:hehe:
  15. stonedsurd
    11 Mar 2009
  16. The_Beast
    21 Apr 2007
    Considering it was 11pm and there wasn't a full moon, lighting was pretty poor. Here are some pics via you're request.
    The top
    Hopefully this meets you're standards
    Overview
  17. KingCake
    KingCake What's a Dremel?
    13 Jul 2009
    B-E-A-U-Tiful!
  18. stonedsurd
    11 Mar 2009
    Oh wow. That's gorgeous.
  19. The_Beast
    21 Apr 2007
    Thanks, be sure to tune into my next project log, it should be up sometime next week
  20. 500mph
    500mph The Right man in the Wrong place
    22 Jun 2007
    It's like a mirror, great job!
