Hi guys, I want to introduce my most recent build, which is in an Ncase M1v2 case. Here is the main component list: -Core i7 4790K -Asus Z97i Plus -Corsair Dominator Platinum 8GB 2133mhz -Asus GTX 760 Mini -Crucial M500 240GB M2 SSD -Silverstone SX600-G Watercooling component list: -EK Supremacy ELITE -Laing D5 from Alphacool -Bitspower D5 mod top -Bitspower D5 mod kit -Swiftech MCR-H220 Radiator -Masterkleer 16/10 Black Tubing -1x Bitspower dual rotary adapter for pump -4x 16/10 black nickel compression fittings Other stuff list: -MNPCTech case feet -Acrylic sheet -White led lightning with rigid pcb. -White leds for d5 top -Black Vandal switch with white led ring -16AWG black cable -connectors for custom cables -MDPC-X black sleeving -Cable combs Now you have seen the specs, and now here are the pictures: First the case itself: I made a custom side panel for the case from 5mm tinted plexi: I got some magnetic strips for the side panel: Custom case feet from MNPCTECH: I've painted them with black Plasti-dip: Cable combs: Rigid pcb led strip: Pump with Bitspower mod kit: Swiftech rad: Fans: EK Supremacy Elite: I assembled the case and did some testfit for the sidepanel and made a custom bracket for the vandal switch. Here is some pics how it looks now: Thats it for now. Im currently working on the custom cables and on the watercooling. Next week the tubing will arrive, then I will be able to finish the cooling loop for the cpu. When the cooling is ready im gonna take some proper pics from the hardware.
Update! I designed a custom case from aluminium for my KBC Poker 2 keyboard, and my friend CNC milled it. Here is the result:
That replacement side panel looks stunning as does the keyboard. Fantastic work. On a selfish side note can you also post what you think of the Silverstone SX600-G when its up and running as I would like to pick one up but i've heard mixed reviews regards coil whine and start up fan noise. Also for the GPU have you looked at the Gigabyte gtx 970 mini itx card? Vents into the case but otherwise looks good. http://www.overclockers.co.uk/showproduct.php?prodid=GX-153-GI Can't wait to see it completed.
The Silverstone SX600-G is a very good psu. I was afraid from the fan noise, because, when ive purchased the psu there were no reviews out there. When you start the system the fan speeds up and back down to 0 rpm. Its not a problem, because it takes less than 2 sec, so its not a problem. There were soma coil noise at the beginning, when I started to use the psu, but it stopped after 2 weeks of use and now, its completly silent, even when im gaming. For the gpu question, yes ive seen the gigabyte gtx 970 mini, but ive already got the 760mini before it launched. Im planning to replace it with the 970 but it costs a lot for me, maybe later Im gonna buy one, but for now the gtx 760 is fine, because i dont play games very often nowadays, so it is good for 2 hour gaming in a month
Subscribed to this! The Ncase looks good but the Plexi panel just added to it! I don't know what it is but the panel just looks good! Plus the Aluminium casing for the Poker. That just needs to be posted in here mate: Mechanical Keyboards
Update! I changed my mind and I switched my fans to the Noiseblocker PL-2-s. I think it fits better to the dark theme.
I finished the cables. I made them from 16awg black wire and sleeved with mdpc-x black sleeve. (sorry for the pic quality) I also recieved the Darkside led strip from MNPCTECH!
I like the case feet generally, but I have to say, I think this particular case looks better with the originals.
Im gonna change the feet after I finished with this build. After I finished this Im gonna make more custom parts for this case and im gonna do a big change in the color of the case, but its gonna take some time to make my plans for the next upgrades and a quite a lot time for making the new parts.
