Case Mod - In Progress Project Prime
Discussion in 'Project Logs' started by Mark011, 20 Jan 2015.
  1. Mark011
    Mark011 Minimodder
    18 Jan 2015
    SPONSORED BY
    Thanks to Alessandro from Ybris Cooling, Peter from EKWB, Luca from Ocaholic and Mike from Phanteks for the help!
    Happy New Year!
    After my first project, pics here, i'm starting the new year with a new worklog! Project Prime is based on a Phanteks case, the Enthoo Primo White Edition, it will be filled with 1x 360x60 + 1x 420x60 radiators, E22 hard tubing, and a full water cooled loop. The main colours are white, red and black.
    Hardware
    i7 4790K
    Asus Sabertooth Z97 Mark S Limited Edition
    Kingston HyperX Fury White 16gb
    Asus GTX770 DC2
    Kingston HyperX 3K White Limited Edition RAID0
    WD Caviar Green 2 x 2TB
    Seasonic SS-860XP2 Platinum + Icemodz.com Handmade Extensions
    Asus Xonar Essence STX
    Liquid Cooling Loop
    Radiators: Alphacool NexXxoS UT60 Full Copper 420mm - White Special Edition + Alphacool NexXxoS UT60 360mm
    Pump: Laing DDC T1 plus + EK X-Top V2 + EK-DDC Heatsink Housing
    Reservoir: EK-Multioption RES X3 - 250 White Edition
    WB CPU: EK-Supremacy Clean CSQ Plexy - Nickel
    WB GPU: EK-FC680 DCII Nickel
    Fittings: Bitspower
    Tube: Nanoxia CF1 PETG Hard Tube 12/10 mm
    Coolants: Nanoxia CF1 UV Red
    Accessories: 2x Aquacomputer Temperature Sensor Inline G1/4 + Bitspower Flow Sensor + Bitspower mini-valve
    Rheobus: Lamptron CW611
    The case just arrived from Germany
    First, I've mounted PSU , HDD and SSD and I've started ordering the back, then I've moved to the front, mounting the motherboard , the supports for the cylindrical tank , the DVD Writer and the Rheobus. I've added 2 strips of bioadhesive to the reservoir supports to improve the grip.
    I've added two LEDs strips, connected to a single 12v case molex which allows me to on/off the lights of the 140mm frontal fans and LEDs.
    The case has a flap cover for the front bay 5.25, this makes it difficult to install a Rheobus which have knobs , but I managed to place my trusted Lamptron FC6 without problems. The space available in flip closed is about 3mm .
    I've started painting the fans and radiators in white for match the build.
    Final photo:
    Angel Vs Devil
    Bitspower Radiator Plate
    Some fitting photos
    Loop
  2. Mark011
    Mark011 Minimodder
    18 Jan 2015
    UPDATE 1
    Fans and Radiators installed
    next step: cpu wb and ddc top paint!
    UPDATE 2
    DDC TOP, HEATSINK and WB BRACKET painted, i think they needs some red now :)
    UPDATE 3
    wb cpu done
    UPDATE 4
    Pump almost finished, I need to colour the engraved text on the top
    I used Plasti Dip Spray on the original ASUS GTX 770 DC2 backplate
    UPDATE 5
    Finally , last Monday the tubes from E22 have been delivered to me directly from England!
    Today was the Slovenia turn, a package from EKWB
    I take this opportunity to thank Peter from EKWB, He will send me 5 of the new EK-CSQ Plug G1/4 (for EK-Badge) - Nickel for free because stop fittings were missed in my previous order, here a pic!
  3. Marcus V
    Marcus V What's a Dremel?
    10 Jan 2015
    Can't wait to see more ;)
  4. Hukkel
    Hukkel James' minion
    20 Dec 2012
    Those fans came out brilliant!
  5. Mark011
    Mark011 Minimodder
    18 Jan 2015
    news will come :)
    Thanks man! ;)
    A new banner and new sponsors :)
    Thanks for the sponsorship
    [​IMG] [​IMG] [​IMG]
  6. Mark011
    Mark011 Minimodder
    18 Jan 2015
    Thank Alphacool and Aquatuning.it for the sponsorship! Unboxing soon!
    [​IMG] [​IMG]
  7. Mark011
    Mark011 Minimodder
    18 Jan 2015
    Banner update!
    A new sponsor. Thank Krystian from HyperX for the sponsorship!
    Some unboxing
    From Slovenia, Thanks Peter from EKWB for 5 EK-CSQ PLUG
    UT60 420 WHITE SPECIAL EDITION sponsored by alphacool and aquatuning.it
    [​IMG] [​IMG]
  8. Mark011
    Mark011 Minimodder
    18 Jan 2015
    Thanks Krystian from HyperX for the sponsorship!!!
  9. Phame
    Phame COOOOFFFFEEEEE
    17 Sep 2012
    Those FANS MANNNNNNNNNNN! Great work! :)
  10. Craig_T
    Craig_T What's a Dremel?
    2 Aug 2014
    That's some awesome work on the fans, makes them look really sweet! I'll be interested to see how this turns out
  11. iancowell
    iancowell Minimodder
    21 Jan 2015
    This looks pretty cool
  12. Mark011
    Mark011 Minimodder
    18 Jan 2015
    Thank you guys :)
  13. Mark011
    Mark011 Minimodder
    18 Jan 2015
    a new baby :)
  14. Mark011
    Mark011 Minimodder
    18 Jan 2015
    Another unboxing today!
    Thanks Mundi from Icemodz.com for the sponsorship of these beautiful handmade extensions!!
  15. Mark011
    Mark011 Minimodder
    18 Jan 2015
    I spent the weekend assembling the hardware, hyperx 3k raid 0 works great, But looks like 1 stick of ram is faulty, the pc won't boot with all 4 sticks mounted, i tried each one alone and i had fake boot with 1 stick, i will try to Contact hyperx for change this faulty stick. I also delidded the 4790k using the vice method and i have applied the Coollaboratory liquid pro on the die. Here some random pics
  16. Mark011
    Mark011 Minimodder
    18 Jan 2015
    Some pics of the cnc's works!
  17. _TechPuppet_
    _TechPuppet_ What's a Dremel?
    1 Feb 2015
    Love the fans, looks great. :thumb:
    Will you be doing anything to the motherboard, such as decals, vinyl, or spray painting? Or do you plan on leaving as is?
  18. Mark011
    Mark011 Minimodder
    18 Jan 2015
    I think the motherboard looks great as it is :)
    I Made a side cover, a 5,25 slot back cover and an hdd cover with plexyglass 3mm
  19. Mark011
    Mark011 Minimodder
    18 Jan 2015
    I have finished the side cover's brackets, it looks perfect now
  20. Mark011
    Mark011 Minimodder
    18 Jan 2015
    some camouflage
