Hello everyone, New year, new mod, new contest .... wow Would like to present my project "Elite Rog Edition" based on case CM Elite 130. I decided to modify this case because I think is one of the best around suitable to host a mini itx and a standard / large vga. I am a lover of things compact, the project is in the final stage will present positioned vertically with a more engaging appearance worthy of being positioned on the desk of a gamer Hope you like it Hardware : Processor: Intel G3258 Motherboard:Asus Maximus VII Impact Ram: Avexir Blitz Series 8GB (4x2) DDR3 1600 C9 Vga: Asus Strix 750 TI Oc SSD: Kingston HyperX 120 gb Power Supply: Cooler Master V750 80Plus Gold Fan: Cooler Master JetFlo 120mm Red Led x3 Water Cooling: Cooler Master Nepton 240M Stay tuned!
Ok guys ..... and here's some image rendering of the project ...... I'm not very good with drawing in 3d but I think the images render the idea ..... during development there will definitely improvements both aesthetic and functional.....
Hello guys, today I started to cut out parts of the case that will be changed and I started modeling the anterior frontal low ..... Stay Tuned
Hello everyone, work continues ....... I proceeded to install the corner profiles in the structure and I modeled support for 120mm fan that will be installed at the top of the case to expel hot air and started to fix the base the structure recovered from the panel's original elite 130
work continues ..... I cut out and built the front of the top of the case .... what do you think? .... Stay Tuned!
Hello guys, I cut the sides of the cover psu which Will it be applied after the plexiglass, I also contoured the cable glands for ssd, USB ports and start button..... Stay Tuned ;-)
Hello guys, are you ready? Pack Arrived !! I'm ready !! I''m very happy........Cooler Master Love!!!! Cooler Master Nepton 240 M with Cooler Master Silencio FP 120 PWM http://www.coolermaster.com/…/cpu-liquid-cooler/nepton-240m/ Cooler Master Power V750 Semi-Modular 80 Plus http://www.coolermaster.com/powersupply/v-sm-series/v750s/ Cooler Master JetFlo 120 Red Led http://www.coolermaster.com/cooling/case-fan/jetflo-120-red/ http://community.coolermaster.com/…/12310-elite-rog-edition/
Looking good, I'm interested in this, got one pick up though The Land clearance on some of those rivet holes, makes me think it's gonna crack around the rivet, fingers crossed they don't! But like I said, I like where this is headed, nice mod!
Hello people, Today I built support for CM Nepton 240M that will go positioned at the front of the case ..... hope you like it Stay Tuned
Hello guys, I rebuilt the front faceplate to measure, will be applied where the start button and USB ports .... it is still to be finished ..... See you soon ;-)
Hello Folks, I continued with a little work. I reinforced the front panel with plexiglass 5mm so as not to have problems with the insertion in the USB ports and I put a LED as light ignition and gave a first coat of paint. I entered the plexiglass panels on the sides of the cover feeder, I gave a pretty smooth at all and I also painted this last, then I gave a first coat of paint also to the houses so that attacks well Stay Tuned ;-)
Hello everyone, I plugged in the side profiles even in the back of the case and started to build the front panel .... See you soon ;-)
Sponsor Avexir Huge thanks to AVEXIR for supporting me with these wonderful memory that will be part of the project http://www.avexir.com/product/blitz/blitz.html Thank you very much Stay Tuned
