Case Mod - In Progress "Elite Rog Edition" Finished
Discussion in 'Project Logs' started by sangyzan, 27 Jan 2015.
  1. sangyzan
    sangyzan What's a Dremel?
    17 Aug 2014
    Hello everyone,
    New year, new mod, new contest .... wow :D
    Would like to present my project "Elite Rog Edition" based on case CM Elite 130.
    I decided to modify this case because I think is one of the best around suitable to host a mini itx and a standard / large vga.
    I am a lover of things compact, the project is in the final stage will present positioned vertically with a more engaging appearance worthy of being positioned on the desk of a gamer
    Hope you like it ;)
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    Hardware :
    Processor: Intel G3258
    Motherboard:Asus Maximus VII Impact
    Ram: Avexir Blitz Series 8GB (4x2) DDR3 1600 C9
    Vga: Asus Strix 750 TI Oc
    SSD: Kingston HyperX 120 gb
    Power Supply: Cooler Master V750 80Plus Gold
    Fan: Cooler Master JetFlo 120mm Red Led x3
    Water Cooling: Cooler Master Nepton 240M
    Stay tuned! ;)
  2. sangyzan
    17 Aug 2014
    Ok guys ..... and here's some image rendering of the project ...... I'm not very good with drawing in 3d but I think the images render the idea ..... during development there will definitely improvements both aesthetic and functional.....
  3. sangyzan
    17 Aug 2014
    Hello guys, this is the cooler master elite 130 ..... Will it be the case that will modify .... :D
  4. sangyzan
    17 Aug 2014
    Ok people, works begin ...... ;)
  5. sangyzan
    17 Aug 2014
    Hello guys, today I started to cut out parts of the case that will be changed and I started modeling the anterior frontal low .....
    Stay Tuned :thumb:
  6. sangyzan
    17 Aug 2014
    Hello everyone,
    work continues ....... I proceeded to install the corner profiles in the structure and I modeled support for 120mm fan that will be installed at the top of the case to expel hot air and started to fix the base the structure recovered from the panel's original elite 130
  7. sangyzan
    17 Aug 2014
    work continues ..... I cut out and built the front of the top of the case .... what do you think? ....
    Stay Tuned! :thumb:
  8. sangyzan
    17 Aug 2014
    Hello guys,
    I started to build a cover to hide the power supply and cables ....
    Stay Tuned! :thumb:
  9. sangyzan
    17 Aug 2014
    Hello guys,
    I cut the sides of the cover psu which Will it be applied after the plexiglass, I also contoured the cable glands for ssd, USB ports and start button.....
    Stay Tuned ;-)
  10. sangyzan
    17 Aug 2014
  11. sangyzan
    17 Aug 2014
    Stay Tuned !! ;-)
  12. stealth80
    stealth80 Minimodder
    1 Feb 2015
    Looking good, I'm interested in this, got one pick up though :D
    The Land clearance on some of those rivet holes, makes me think it's gonna crack around the rivet, fingers crossed they don't!
    But like I said, I like where this is headed, nice mod!
  13. sangyzan
    17 Aug 2014
    Thank you very much :thumb:
    mmmmm .... I hope that the rivets remain in place :D
  14. sangyzan
    17 Aug 2014
    Hello people,
    Today I built support for CM Nepton 240M that will go positioned at the front of the case ..... hope you like it ;)
    Stay Tuned :thumb:
  15. sangyzan
    17 Aug 2014
    Hello guys, I rebuilt the front faceplate to measure, will be applied where the start button and USB ports .... it is still to be finished .....
    See you soon ;-)
  16. Vetalar
    Vetalar *learning english*
    21 Jun 2011
    woudn't be easy to start from silverstone ft03?
  17. sangyzan
    17 Aug 2014
    I do not like easy jobs ;) and the Silverstone FT03 is the biggest of the CM elite 130
  18. sangyzan
    17 Aug 2014
    Hello Folks, I continued with a little work.
    I reinforced the front panel with plexiglass 5mm so as not to have problems with the insertion in the USB ports and I put a LED as light ignition and gave a first coat of paint.
    I entered the plexiglass panels on the sides of the cover feeder, I gave a pretty smooth at all and I also painted this last, then I gave a first coat of paint also to the houses so that attacks well
    Stay Tuned ;-)
  19. sangyzan
    17 Aug 2014
    Hello everyone, I plugged in the side profiles even in the back of the case and started to build the front panel ....
    See you soon ;-)
  20. sangyzan
    17 Aug 2014
