Case Mod - In Progress HeretEK-An EK Vulture build
Discussion in 'Project Logs' started by B NEGATIVE, 16 Feb 2015.
  1. B NEGATIVE
    B NEGATIVE All Hail Kim Jong Magoo!
    8 Aug 2011
    Welcome one and all to a project I have running concurrently with IDORU,a build for the EK mod off event using their not to be released EK Vulture enclosure!
    The event!
    The case in all its glory!
    Word dont do justice,its 3mm construction is overkill but damn its lovely!
    Lots of room internally for ITX.
    360 mount and the slim slotloader optical bay.
    Behind the tray lies the SSD/HDD area and cable management,plenty of room to hide the 'uglies' if extensions are your thing.
    The EK PE 360 rad that i will be using...
    ...and the 1850 Vardars that will be mounted on them
    Since this is a mod-off....maybe this will indicate what kind of mod im doing.....
    I hope the 360 is enough........​
  2. hairyknacker
    hairyknacker Minimodder
    25 Jan 2012
    B,
    You sir are a modding God- go get em cowboy:D:D
    where is a cheerleader emoticon when you need one :D
  3. Hukkel
    Hukkel James' minion
    20 Dec 2012
    I am here buddy. Enjoy you project!
  4. Impatience
    Impatience Minimodder
    6 Apr 2014
    Warhammer Chaos themed? (Guessing from the logo) Awesome! :clap:
  5. B NEGATIVE
    8 Aug 2011
    Steady fella,im middle management at best....:D
    Cheque to the usual?
    :thumb:
    You are always in early mate!
    Yup.
    http://warhammer40k.wikia.com/wiki/Heretek
  6. Impatience
    6 Apr 2014
    I'm hooked already! *Subbed*
  7. montymole
    montymole Rigid Tubist
    24 May 2010
    I am in :)
  8. bulldogjeff
    2 Mar 2010
    I've see pic of these cases and the look really nice.. Looking forward to see what you do with this one.
  9. B NEGATIVE
    8 Aug 2011
    :thumb:
    About time too!
    Thanks Jeff,Knowing that it is never to be released just makes me want to squirrel it away..
    However,i cant resist trying to get a Sli x99 in there...because....you know....I can. :rock:
  10. bulldogjeff
    2 Mar 2010
    It wouldn't be modding if you didn't put things where they're not supposed to be Then chop a few things up and turn it all upside down:D
  11. B NEGATIVE
    8 Aug 2011
    BLOCKS FOR THE BLOCK GOD!
    The GPU blocks that will be used,a pair of 290's will be going into this one....
    I bet you are looking at this now thinking...."Not a lot of rad for those...." Well,this is also an experiment after seeing a few Sli rigs with OC'ed CPU's with minimal rad face.
    The cards wont be OC'd but the CPU most definitely will be!
    Dont worry,modding and paint start very soon for those with the itch.​
    Very true.
    I dont like to lose the case features tho,I like it to remain close to the original but adapted to what I think it could be like.
  12. Mockingbird
    Mockingbird What's a Dremel?
    7 Sep 2011
    Hmmmm... Chaosy goodness. That case looks like a really nice build - I'd be so tempted to just build in it as-is rather than mod it.
    Ha ha ha just kidding, get the hacksaw.
  13. Maki role
    Maki role Dale you're on a roll... Lover of bit-tech
    9 Jan 2012
    Figured I'd drop in early on this one too, really looking forward to seeing what you do with the case!
  14. Bartacus
    Bartacus Minimodder
    30 Oct 2014
    Damn, forgot to sub over here too. I'm gettin' old!
  15. B NEGATIVE
    8 Aug 2011
    The main hardware is all sorted which left me wondering what PSU to use,I asked Be Quiet again as their PSU's have always been solid performers for me,I like them so much that im on my 6th one.
    To my joy they said yes!
    So its my pleasure to say the BeQuiet will be sponsoring the PSU for this build and the PSU and fans for IDORU!
    I went with PowerZone 1000w,that will be plenty for a x99 sli rig and watercooling.
    http://www.bequiet.com/en/powersupply/384
    Thanks Be Quiet UK!
    The all important spec sticker.
    After the happiness of that,some modding broke out.
    I have chopped the side panel with an EK logo,this will be meshed over and lit from behind.
    And I started on the back panel..
    still needs the screw holes drilled and the cutout for the removable tray done but....
    The removable tray,a spare part from Lian Li.
    Next up is mount the tray and clear out all the unused parts in the case.
    3mm Alu......the jigsaw loves it!​
  16. ciobanulx
    ciobanulx Modder / Watercooler
    24 Jul 2014
    I really love your work! Can't wait to see what you do with this case :D
  17. B NEGATIVE
    8 Aug 2011
    I gots me some new hardware!
    Wait a minute.....this is not a 2011.....
    Ah...wait....there it is....
    Its not about the size they say.....how can this be? I haz proof this is not so....
    And the board in all it glory!
    The DDR4 kindly provided by Crucial!
    Suited and booted and ready to paaaaaartaaaaayyyyyyyyy!!
    Those DIMMs and this board=WIN.
    In other news,the case structure is painted and just needs a clear,the sides and front need other stuff doing. Its coming together well but painting takes time that has been swallowed up on other projects. Still,the deadline is a way off yet!
  18. MODZERO
    MODZERO Minimodder
    29 Jun 2011
    Very exciting, I'm glad you've modded the case to M-ATX it seems to have plenty of room for it. Cant wait to see what you do.
    J.
  19. Freebee
    Freebee What's a Dremel?
    6 Nov 2014
    Great idea, the case looks a bit overkill for just an itx system!
  20. B NEGATIVE
    8 Aug 2011
    Its a new obsession for me now,cramming for the WIN.
    Good news!
    Noob? @ Bittech had a pair of 290's for sale and I try not to turn a good deal down,especially GPU's..
    The hardware needs to be blacked out before getting that all buttoned up but the block suits in shape,although i may swap the top out for an acetal one.
    As for the kit....
    See? Nothing special......​
