Scratch Build – Complete Project Alternate 'COMPLETED'
Discussion in 'Project Logs' started by Deblow, 10 Mar 2015.
  1. Deblow
    Deblow Minimodder
    12 Dec 2013
    Project Alternate: PC in a desk scratch build & MODs
    Hi all,
    After what feels like a very long year I have decided to start work on my new desk build.
    The idea for this desk came to me when i was working on my last desk & at one point I almost started the project
    again, but I'm glad i didn't
    Most people liked the desk & I learned a great deal during the build.
    The Project Alternate design slightly changed month by month & I will show some of the other plans & explain why the changes was made.
    This time I'm hoping to outdo my last desk & hopefully help others in the process.
    The desk work is about to start, using mostly MDF, Perspex, clay, metal & glass I plan to build the desk in 3 parts,
    starting from the bottom, then middle followed by the top section.
    the tricky parts will be the sharp corners & angles on the edges.
    In making the desk in 3 parts it will allow for easy transport from my garden shed to my
    very small room/office.
    I plan to have the 2 reservoirs just under the top shelf so i can see the water flowing by :)
    have a couple of different layouts for the internal components,
    but want to wait until the top compartment is built so I can see IRL what looks & works best.
    For the specs, I'm upgrading from my trusty i5-2500k to a i7-5820K, due to the CPU upgread I will also be using the new ASUS X99 TUF
    motherboard & DDR4
    This time I will also go with 3 screens at 1440p if possible, or 1X 4K screen, so my HD7970s will also need upgrading to a R9-295x2.
    The desk is going to take months to complete, so rushing out for parts now is not necessary unless it's something on sale I can't pass on :D
    **UPDATE 18/10/15: some Specs**
    SPECS
    CPU - i7-5820k
    MB - ASUS Sabertooth X99
    RAM - 32GB Avexir Blitz 1.1 (DDR4)
    GPU - ASUS R9-295x2
    PSU - Cooler Master: V1200 Platinum
    PSU2 - Cooler Master: GM750W
    Fans - Cooler Master: Jet flow 120's & Cooler Master Silencio FP120 PWM
    HDs - Western Digital Green 6TB - Barracudas x2 2TB - Wester Digital Green 1TB
    SSDs - 2x Samsung EVO850s 250GB (500GB)
    RADS - 2x Phobya G-Changer 360 RADs V.2
    RES - 2x Phobya 450 reservoirs
    CPU WB - Alphacool NexXxoS XP³ Light
    PUMP - 2x Alphacool VPP655
    GPU WB - Alphacool NexXxoS GPX
    KB - CM Storm quickfire xti
    Mouse - CM Storm Reaper
    For people that just want to see the photos & the build progress here are the build log vids
    The final will be added later.
    Build log 1
    Build log 2
    Build log 3
    Desk top lift
    Thanks to the sponsors.
    Cooler Master UK, CM Storm, ASUS ROG, Phobya, OCOOL/Alphacool Mayhems GT Omega Racing & Avexir
    For past & present MODs/Builds please check my Facebook & Youtube pages.
  2. Stallion
    Stallion What's a Dremel?
    30 Jul 2014
    got some interesting angles to tackle there i shall watch fellow desk builder
  3. Deblow
    Deblow Minimodder
    12 Dec 2013
    The angles are going to be a challenge, never attempted to cut them before.
    I think cutting just one side wont be so bad but when i get to the bits that need 3 sides doing all at different angles I will fail a couple of time :duh:
  4. darknessblade
    darknessblade What's a Dremel?
    23 May 2014
    from what i can see in the pic/ render it might be look cool
  5. Deblow
    Deblow Minimodder
    12 Dec 2013
    Thanks both ;)
    I know it looks a bit strange compared to most other PC desk builds, that was the main goal, to have something a bit different.
    the angled sides are around 11" at the widest points & I plan to use them as extra storage if possible, because the RES are going on the outside I will be left with lots of space inside to try fill, might leave room for a second PC at a later date, or maybe add some consoles
  6. Deblow
    Deblow Minimodder
    12 Dec 2013
    here is one of the many 1st designs i did, had to change it due to the size :(
    After the wife told me to move all my model cars from the living room, this cabinet ended up in the garden, I was planing to use the glass from this
    on the next build & was one of the main reasons the desk is so angled, I also love the Honda CBR600RR due to its sharp looking design & ofc Lambos have the same sharp designs that i love,
    now due to the design changes I cant use the glass so will be using fresh cut glass or thick perspex.
    The MDF for the 2 bottom sections along with most of the MDF for the middle have now been cut to size & I have started to assemble.
    I was told to kit myself out with a face-mask & glasses when cutting MDF,
    but the normal size face-mask was causing my glasses to steam up lol
    So had to dig out my airsoft mask to use in conjunction with the small face-mask
    Some of the bolts/screws I will be using to fasten the main parts together, they will make it more easy to remove with standard alan keys & should last longer.
    Sides ready to be fasten to the bottom & back, soon as the miter edges are done
    The hardest part so far, miter edges, very tricky & most the time i have to use scrap wood before doing the final peace or risk wasting some MDF
    My 1st set of angled corners cut ready to use as shelf's/frame
    Bottom left assembled
  7. Bartacus
    Bartacus Minimodder
    30 Oct 2014
    Subbed! I love desk builds. :)
  8. Craig_T
    Craig_T What's a Dremel?
    2 Aug 2014
    Another love for desk builds :D
  9. Deblow
    Deblow Minimodder
    12 Dec 2013
    Thanks Bartacus :thumb:
    Love making them even more, bit stressful sometimes, still very rewarding if the desk goes to plan :D
  10. Deblow
    Deblow Minimodder
    12 Dec 2013
    A bit later than planed but finally got time now to update the log :)
    Both bottom left & right shelf's/frames are completed, no permanent fittings just encase i have any problems moving the desk to the house,
    This was by far the easiest part so far
    The main compartment that will act as a frame for the top & hold the fans & other components - the RADs
    Here im making some slots for the front panels that will be resting on the left & right side shelf's, doing so will help hold them im place as I screw them down
  11. Stallion
    30 Jul 2014
    The joys of MDF, looking good thus far
  12. Deblow
    Deblow Minimodder
    12 Dec 2013
    Tell me about it :D
    the dust is a pain though, even with a vac & dust mask
    Over the past week some build items have arrived so I will cover them along with the case mod im doing
    Moving the MEGA desk build (2013) in to the case to make room for the new desk & to ensure I have a working
    computer during the build so I can keep you all updated :)
    My 1st package had some Cooler Master bit n bobs that I will cover later in the build
    along with my replacement tea cup & cap :D
    2nd package had the heart of the new build, A v1200 PSU along with Jet Flow 120mm RED fans & some
    very nice Resonar in-ear buds so I can have some decent music as I'm working in the shed :)
    And last thing I received this week was my new CPU, Intel i7-5820k witch will be a nice upgrade for me
    the last CPU I was using was the i5-2500k.
  13. Deblow
    Deblow Minimodder
    12 Dec 2013
    Moving the old desk build to a cooler master silencio 652s case..
    Wrapping with some 3M vinyl wrap (brushed silver)
    Case broken down ready for the wrap, fairly easy to do
  14. Deblow
    Deblow Minimodder
    12 Dec 2013
    Building from bottom to top, the sides are cut and attached with screws & glue,
    decided to use some old wood for this part to test out the new saw & my skills with mitering
    In the end I was so happy with the results I kept the old wood & didn't bother redoing them with MDF :)
    This bit was tricky, wood too deep for the dremel, design to narrow for the multi tool :(
    Ended up having to use a bit of everything including a hand saw & blade.
    Now time to cut the part that will allow my legs to go under the desk, then for the 1st time I can sit at the desk to get a feel for how it
    will be when completed.
    This is one of the drive bay holder cutouts, again with the older wood
    The final update for this weekend is the start of the two shelf ends that will also act as speaker boxes
    Hope you enjoyed the updates, please let me know your thoughts as I progress, good or bad, still time to change things if needed :D
    Have a nice weekend
    Rob
  15. Stallion
    30 Jul 2014
    Well done, you did a fine job there thus far :clap:
  16. Deblow
    Deblow Minimodder
    12 Dec 2013
    Thanks, yeah the wrap looks very nice now its on, the 3M wrap is a bit thicker than the cheaper ones so a bit harder to use without heat.
    should take damage better & last longer though :)
    Thanks Stallion, yeah this time its going a lot faster & more easy with the correct tools..
    Just the MDF dust thats a pain :wallbash:
  17. Deblow
    Deblow Minimodder
    12 Dec 2013
    My new GPU has arrived :D
    ASUS R9-295x2
    been testing it out on my current rig & im very happy so far, BF4 FPS are now over 120FPS maxed out @1440p
  18. Deblow
    Deblow Minimodder
    12 Dec 2013
    Both the corner parts now built, they will house the speakers & also act as part of the upper shelf for the monitor/monitors.
    When I was happy with all the parts & placement I then went back to the corner parts to add the speakers, did it in this order so i could double check how it looked
    before adding the speakers, just encase I wasn't happy with them in the position I had them on the art work.
    This is a dodgy tool, almost had my hand of a couple of times, but did the job in the end :)
    Added some sealant to prevent dust & help with the speaker sound.
    Starting to take shape now, really nice to see it looking a bit like the design I spent months working on :D
    please note, the sides ain't fasten down yet & still need some sanding to be done later in the build,
    the shelf is also just resting there atm, the blocks holding it up are just for demonstration & will be replaced.
    In the next stage im going to dismantle the desk & reduce the height by 2 inch, the main reason for this mod is so im not towering
    above my friends on my high chair as they sit on the small visitor chairs :)
  19. Stallion
    30 Jul 2014
    looking good, shame to reduce hight just to stop being taller than your friends. i would want to be taller, God like, looking down at your minions :)
  20. Waynio
    Waynio Relaxing
    20 Aug 2009
    Looking good. :)
