Case Mod - In Progress FINISHED : Silverstone TJ 07 WaterCooling MOD
Discussion in 'Project Logs' started by LuZmA, 27 May 2011.
  1. LuZmA
    LuZmA What's a Dremel?
    9 Aug 2010
    Hello!
    First, i advise you my english is not the best, so excuse me if you see any mistake. i'm doing my best
    This year i am going to do an aesthetic mod, i have chosen this case because it is perfect for what i want to do :)
    1º Sponsor
    2º Sponsor
    3º Sponsor
    4º Sponsor
    5º Sponsor
    6º Sponsor
    7º Sponsor
    8º Sponsor
    UPDATES
    WaterCooling
    http://forums.bit-tech.net/showpost.php?p=2704266&postcount=4
    Unboxing of the case
    Inversion of mobo tray
    Unboxing of the Gigabyte P67A-UD4 and an i5 2500K
    http://forums.bit-tech.net/showpost.php?p=2696100&postcount=2
    Topgrill made by a CNC machine :dremel:
    Some parts made by CNC
    http://forums.bit-tech.net/showpost.php?p=2711958&postcount=10
    OCZ VERTEX 3 120GB
    http://forums.bit-tech.net/showpost.php?p=2718125&postcount=17
    The side panel cut by a water jet cutting machine
    http://forums.bit-tech.net/showpost.php?p=2729297&postcount=22
    Mounting the parts
    http://forums.bit-tech.net/showpost.php?p=2735964&postcount=24
    The electronic
    http://forums.bit-tech.net/showpost.php?p=2744257&postcount=27
    Euskal Encounter 19
    http://forums.bit-tech.net/showpost.php?p=2762153&postcount=33
    3M DI-NOC Carbon Fiber Vinyl
    http://forums.bit-tech.net/showpost.php?p=2774147&postcount=34
    Material given by ColdZero
    http://forums.bit-tech.net/showpost.php?p=2795705&postcount=36
    Material given by Atlas Informática & Corsair
    http://forums.bit-tech.net/showthread.php?t=210240&page=2
    Last Pics
    http://forums.bit-tech.net/showpost.php?p=2945137&postcount=43
    Design
    I have worked hard to do this design
    As you can see, the silverstone temjin black 07 is (at least for me) a special case for work and modify
    this is the topgrill, it is made of acrylic.
    The faceplate, topgrill etc. will be done by a CNC machine.
  2. LuZmA
    9 Aug 2010
    WaterCooling
    here i have some watercooling components.
    1/2" Primoxil PrimoFlex Pro 19/13
    EK Waterblocks EK-Multioption RES X2 - 250 Advanced
    CPU Block Supreme HF Plexi/Nickel
    Radiator Swiftech MCR420
    Laing DDC-1PlusT/12V and an ek x-top v2
    It didn´t fit in my car !!
    Thank god, i have a good trunk
    Look at that effect
    Well, it´s dremel time, as you can see, im going to invert the mobo tray
    This is a good screwdriver xD
    Well, i´m removing little by little the parts of the case
    that screw was a pita, so i cut it with the dremel
    :rolleyes:
    I´m sorry about some pics, because i took it at night
    I put some filler at these holes
    Holy tape...
    As you can see, i put some brass motherboard standoffs to elevate the mobo tray
    Close and it´s done :)
    Speed likes this.
  3. ColdzeroTeam
    ColdzeroTeam What's a Dremel?
    9 Dec 2010
    nice stuff :)
  4. LuZmA
    9 Aug 2010
    Here is my brand new mobo,
    Gigabyte P67A-UD4
    And my new cpu too, an intel 2500K processor
    The worst CPU fan, powered by nidec ...
    Greetings
  5. LuZmA
    9 Aug 2010
    This is the topgrill, is made by a CNC machine
    Greetings and comment please
  6. Blooddrunken
    Blooddrunken In Flames we Trust
    8 Apr 2010
    The concept looks nice - I'm looking forward for this build. :)
  7. lilgoth89
    lilgoth89 Captin Calliope
    12 Mar 2011
    hey, you mention your using a 420mm rad ? this would be 140x3 but the rad in your pic is a quad... wondering if you ment a 480mm :naughty:
    anyways. awesome looking project i love the tj07
    its amazing people are still finding new things to do to it
    :rock: :rock: :rock:
  8. LuZmA
    9 Aug 2010
    Thanks
    :cooldude:
    No, i mention the name of the radiator, its length is about 55 cm approximately
    http://www.sidewindercomputers.com/swmcqupo4xbl.html
    xD
    Well, i´m going to update this worklog soon :naughty:
    Greetings :)
  9. lilgoth89
    12 Mar 2011
    thats an oddly named radiator lol
    i would have thought being a 120x4 it would be called a 480 ( like the naming of most rads )
  10. LuZmA
    9 Aug 2010
    New UpDaTe!
    This is the part of fans
    I have to sand it
    Here is the topgrill, don´t worry, the plastic protector is below it
    This is the frontal, it is made of 3mm aluminium
    Greetings and comment please :)
  11. bagman
    bagman Minimodder
    18 Apr 2009
    this is starting to shape up very nicely indeed
  12. Tna
    Tna Moda'a'foca modding power!
    18 Jan 2011
    very nice project, im folowing
  13. LuZmA
    9 Aug 2010
    :dremel: Thanks :dremel:
  14. LuZmA
    9 Aug 2010
    Let´s make a little comparison between:
    Sketchup
    Reality
    Greetings!
  15. ColdzeroTeam
    9 Dec 2010
    that front panel looks pretty good :)
  16. socal-mods
    socal-mods What's a Dremel?
    8 Jun 2011
    wow! nice renders
  17. LuZmA
    9 Aug 2010
    Well, it's time to update this thread :)
    This is the 4º sponsor
    ProSilent PC
    And as you can see, i have a new SSD :)
    OCZ VERTEX 3 120GB
    Greetings :clap:
  18. Toxicgrx
    Toxicgrx What's a Dremel?
    6 May 2010
    Luzma you know I really like this mod.
    I hope to see completed in the Euskal Encounter 19 in July. :clap:
    ReGards!
  19. Hawkest
    Hawkest I got some 4GB new RAM
    22 Jun 2009
    I'll be keeping a close on this, its looking very good!!!
  20. bruce_rob
    bruce_rob What's a Dremel?
    18 Apr 2010
    looks amazing
    cant wait to see the progress
    loving the vertex 3 (dribble)
