News Crysis minimum specs released
Discussion in 'Article Discussion' started by Tim S, 24 Jul 2006.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. ChromeX
    ChromeX Minimodder
    12 Aug 2004
    Wow pretty hardcore, I just make the minimum requirements. Lets face it when a manufacturer tells you the minimum they really do mean the MINIMUM! Time for an upgrade I think!
  3. The_Pope
    The_Pope Geoff Richards Super Moderator
    3 Jul 2003
    Considering the game is 6+ months away, plenty of time for prices to tumble :)
  4. saeghwin
    saeghwin What's a Dremel?
    1 Mar 2006
    I'm below the recommended specs in a couple of areas. Not by much though (7800 GT, 1GB RAM, A64 3700+). I'll probably upgrade in a couple of months.
  5. fargo
    fargo What's a Dremel?
    13 Feb 2006
    with my p4 3ghz 2gigs of ram and my 850xt I think I will be quite
    comfortable but for the follow up to crysis I'm sure to need an over
    haul! can't wait!!!
  6. Darkedge
    Darkedge Minimodder
    26 Nov 2004
    got minimum.. ouch.. This game will rock though
  7. mattthegamer463
    26 Nov 2004
    For the first time ever my PC has been beaten by the minimum requirements. Like, FEAR came close, but this has butchered my PC. Mine would crash during the installer if I tried to play this game. Good thing I'm doing a full overhaul in January, then I can play!
  8. aggies11
    aggies11 What's a Dremel?
    4 Jul 2006
    I don't think we can call this quite "official" as of yet. From what I've heard, Crysis-Online is a Crytek Endorsed Fansite. And the post was a "educated guess" from an admin on that site. Ie. Not from a Crysis developer.
    Looks like the website is down due to traffic, which would go in line with the idea that it's a fansite.
    Doesn't mean the specs aren't accurate though. Only time will tell :)
    Aggies
  9. Cheap Mod Wannabe
    Cheap Mod Wannabe What's a Dremel?
    7 Feb 2005
    Wow is this the first game that recommends Dual core? This should be optimized hard core for multi threading.
  10. BoomAM
    BoomAM What's a Dremel?
    7 Nov 2003
    I'd imagine that the second core would be used for the physics processing, for the fancy effects seen in the videos.
    Apart from my video card, my PC is just over the recommended spec. However, i'd imagine that 2Gb ram/X2 3800/whatever the top gfx card is at the time will play it fine & dandy. :p
  11. K.I.T.T.
    K.I.T.T. Hasselhoff™ Inside
    1 Jan 2005
    wow, its kinda depressing when the minimum requirments for a game reads like the spec for your best rig (sig rig in my case).
  12. PA!N
    PA!N What's a Dremel?
    16 Jul 2005
    Recommended Specs:
    * CPU: Dual-core processor (Athlon X2/Pentium D/Core 2 Duo); NO
    * GPU: NVIDIA GeForce 7800 GTX / ATI Radeon X1800XT (SM3.0) or
    directX10 equivalent; NO
    * RAM: 1.5GB; YES
    * HDD: 6GB; YES
    * Internet: 512k+ (128k+ upstream); YES
    * Optical Drive: DVD; SURE
    * Software: DirectX 10 with Windows Vista MAYBE
    Sadly my rig doesn't quit match the high specs...BUT I think I might have upgradind to Conroe by releas (If I dont get a macbook)
    This game will be a killer :rock:
  13. Kasrkin Guard
    Kasrkin Guard What's a Dremel?
    19 Mar 2005
    Anyone notice the site that is linked is down??? :worried:
  14. wharrad
    wharrad Minimodder
    26 Jul 2003
    Hoping it'll work on the slight overclocked 2.13Ghz Pentium M I'm using for a media/gaming machine... The rest of the specs are alright - although the 7900 GPU is close.
    Got to think though in a living room gaming environment, the screen is only 1280x768 (or 1280x800, I forget)... So it's not to harsh on the GPU anyway.
  15. DougEdey
    5 Jul 2005
    I want to know WHEN DX10 cards are out and WHICH cards they are!
  16. Fr4nk
    Fr4nk Tyrannosaurus Alan !
    12 Mar 2005
    * CPU: Dual-core processor (Athlon X2/Pentium D/Core 2 Duo); Kerching
    directX10 equivalent; Kerching
    * RAM: 1.5GB; Soon to be 2gb for me
    * HDD: 6GB; Yesh
    * Internet: 512k+ (128k+ upstream); Yesh, suck on 10mbit/384kkbit :p
    * Optical Drive: DVD; Well duh
    * Software: DirectX 10 with Windows Vista Probably
    On the borderline for reccomended, so I'm reasonably happy :)
  17. zr_ox
    zr_ox Whooolapoook
    5 Jan 2005
    Recommended 1.5 :sigh:and the rest of the spec's :waah:
    I just cant do it captain I dont have the power!
    Well maybe its time to get 4GB of these badboys for my next rig. :naughty:
  18. ou7blaze
    ou7blaze sensational.
    5 May 2003
    Athlon XP 2500+ @ 2ghz
    ASUS A7n8x deluxe
    Radeon 9800 Pro
    2x 256mb DDR RAM
    Can you feel the power of my rig???
    No, not really, I can JUST about play Battlefield on LOWEST settings, overclocked, *sigh*.
  19. DeX
    DeX Mube Codder
    22 Jul 2002
    No, the specs don't suprise me at all. In fact I don't even bother looking at today's bleeding edge games as their specs have always been miles above the level of my 4.5 year old AthlonXP 1900 and GF4. Still can't wait for the game to arrive though!
  20. Tim S
    Tim S OG
    8 Nov 2001
    The physics engine is done using one of the two CPU cores, I'd reckon :)
Tags: Add Tags
