Hardware PC Hardware Buyer's Guide: August/September 2012
Discussion in 'Article Discussion' started by brumgrunt, 31 Aug 2012.
  1. brumgrunt
    brumgrunt What's a Dremel?
    16 Dec 2011
  2. YEHBABY
    YEHBABY RIP Tel
    22 May 2010
    I'm glad to see you have added a mini ITX recommendation. But a section on HTPC's would be nice as I finding the choices a little bewildering and could do with some guidance on what to buy.
    Landy_Ed likes this.
  3. Pookie
    Pookie Illegitimi non carborundum
    4 May 2010
    Surprised that the i30 fits on the Asus mini itx board
  4. Digi
    Digi The not-so-funny Cockney
    23 Nov 2009
    Hah, I could have garunteed the usual 'HTPC' comment but coming as it did, in the first comment, made me grin.
    Nice to see the gaming workhouse, which more or less is what I purchased 2 months ago, recommending the same parts. Vindication of hours of slaving over spec and being paranoid over this or that choice!
  5. adam_bagpuss
    24 Apr 2009
    personally id opt for the i3-2120 over the 2100 since its 200mhz faster and exactly the same price
  6. docodine
    docodine killed a guy once
    10 Feb 2007
    The Prodigy really fits a 660ti with the top cage in?
  7. YEHBABY
    YEHBABY RIP Tel
    22 May 2010
    Thanks. I always aim to please. ;)
    Sent from my BlackBerry 9300 using Tapatalk
    Teelzebub likes this.
  8. RealWeaponX
    RealWeaponX What's a Dremel?
    16 Mar 2012
    I'm building a new system from scratch on a reasonably tight budget, but I'm willing to stretch the budget and wait another month to build if need be. I was going to build an AMD A8 system and dual-graphics mode it at a later date, but would I be better off spending a little more and going the route of an LGA 1155 system with discrete graphics?
  9. Combatus
    16 Feb 2009
    Don't forget the Zotac 660 Ti 2GB we've recommended is the super-short PCB version...
  10. Combatus
    16 Feb 2009
    The AMD A-8 3870K is quite overclockable - certainly enough for it to give the Core i3-2100 a run for its money. However, getting the Intel CPU and a discrete graphics card will always be the better option - the 2100 is far more power efficient and an LGA1155 system has far more upgrade potential. Socket FM1 is really only for those on a very tight budget, or for HTPC systems that need a bit of gaming grunt over the usual poor on-board graphics. If you can afford it, go for the LGA1155 option.
  11. GuilleAcoustic
    GuilleAcoustic Ook ? Ook !
    26 Nov 2010
    Nice ITX rig, but the prodigy is still too fat for me considering it as "ITX" case. A Lian Li PC-Q08 can house ATX PSU, Corsair H60, 300mm GPU, 4x 3.5" + 1x 5.25" + 1x 2.5". Even if you get rid of the 2 HDD bays, the optical bay can still hold a full fat optical + 1x 2.5" HDD / SSD ... but that's only my personnal preferences regarding the "ITX" rig label :D
  12. Combatus
    16 Feb 2009
    I've actually just swapped this to a Corsair H80, which I know fits both the board and the case without sacrificing drive bays - something I hadn't considered. A Noctua NH-D14 does fit on the P8Z77-I Deluxe though!
  13. docodine
    10 Feb 2007
    Could you post a photo sometime?
  14. RealWeaponX
    16 Mar 2012
    Thanks, I think I'll hang on the extra month or so and go Intel then. :)
  15. GuilleAcoustic
    26 Nov 2010
    OM nom nom, it would fit a PC-Q11 perfectly :D
    EDIT : It would also fit a PC-Q08 with the 2 HDD bays installed :D
  16. docodine
    10 Feb 2007
    I know that card, I saw the Bit review of it recently, I meant a pic of the card in a Prodigy if possible, sorry if I wasn't clear :(
  17. mystvearn
    mystvearn any-may
    12 Feb 2009
    Kudos for the mini-ITX build guide:)
  18. GuilleAcoustic
    26 Nov 2010
    I found a pic of this card on an ITX mobo (maybe the shroud will block the lower HDD caddy (nothing a dremel can't fix)
  19. Tyrmot
    Tyrmot Minimodder
    12 Mar 2008
    Great to have the mini-ITX added! Thanks!
  20. MrJay
    MrJay You are always where you want to be
    20 Sep 2008
    Loving the mini-ITX addition : )
    However the Asus P8Z77-I Deluxe is overkill, much cheaper variants for the Z77 about.
    Also i have herd allot of bad things about the build quality of that case.
    But hey I'm fussy.
Tags: Add Tags
