Watercooling What coolant do you use? Show us with pictures!
Discussion in 'Hardware' started by Parge, 18 Mar 2013.
  1. Parge
    16 Jul 2010
    Went from distilled water - which my Nickel Plated EK GPU blocks didn't like - to Phobya ZuperZero, which is great for Four reasons:
    Cheap as chips (£6 for 1L)
    Doesn't corrode my blocks in any way (well, after about 9 months all good)
    Didn't stain any of my Plexi blocks (gave them a quick clean and scrub and all residue just washed away)
    Amazing glow under UV light (see below).
    Untitled by Penderyn, on Flickr
    That was my old build, just finished the one in my sig, currently using Mayhems Ultra Pure water, with Feser One corrosion blocker, but planning on replacing it with something colourful when the Deep Silence windowed side panels are released.
  2. Guest-23315
    Guest-23315 Guest
    Deionized water from Halfords.
    Silver kill-coil.
    Nuffin' else.
  3. Big Elf
    23 Apr 2009
    Distilled water from Barbers and Benzalkonium Chloride. I stopped using De-ionised water and silver kill coils when I realised it was highly possible they were the cause of nickel being stripped from one of my blocks.
  4. jizwizard
    jizwizard Modder
    24 Dec 2010
    Good old fashioned council pop in mine
  5. bodkin
    bodkin Overheating
    8 Apr 2009
    As in tap water?! Heathen!
  6. bulldogjeff
    2 Mar 2010
    Plus one to the Halfords juice, works just fine for me.
  7. Guest-44432
    Guest-44432 Guest
    Filter tap water. Good enough for home heating, good enough for watercooling. Nuff said! :D
  8. Shirty
    18 Apr 1982
    Piss. I like the aroma when opening the loop up after six months.
    I'll spare you the picture.
  9. jinq-sea
    15 Oct 2012
    Mmmm. Warm ammonia!
  10. bdigital
    bdigital Is re-building his PC again
    10 Aug 2010
    Tangster likes this.
  11. Guest-23315
    Guest-23315 Guest
    6 years of it and not a dead system yet!
    Ran Feser One once... eugh. Gunk everywhere.
  12. Burnout21
    Burnout21 Mmmm biscuits
    9 Sep 2005
    +1 same here. If the loop is clean upon assembly then no worries of growth either.
    I boiled all my LC parts, helps remove nasties before assembly
  13. Margo Baggins
    Margo Baggins I'm good at Soldering Super Moderator
    28 May 2010
    In my old watercooled: Feser One Red - looked alot more pink than red.
  14. Parge
    16 Jul 2010
    Woah! Snakepit!
    That is the reason I've not done a ROG build - Red stuff always looks pink to me. Some of the Mayhems blood red coloured stuff is better, but not UV reactive so.....
    What I'd really like is UV orange coolant, but I can't seem to find any.
  15. David
    7 Apr 2009
    This.
  16. Tangster
    23 May 2009
    EK UV blue as well.
  17. Parge
    16 Jul 2010
    Nice! You got any shots of that under UV?
  18. The_Crapman
    5 Dec 2011
    EK Clear:
    In black tubing... ;)
  19. Parge
    16 Jul 2010
    Haha! Is that my old Kuhler!? Awesome!
  20. Tangster
    23 May 2009
    I'll dig out the CFLs and take some pics tonight. :D
