Motherboards Good mITX mobo for i7 4770
Discussion in 'Hardware' started by Siberdine, 6 Jul 2014.
  1. Siberdine
    Siberdine Safety Not Guaranteed.
    1 Aug 2010
    As an early birthday present, my dad bought me an i7 4770 (non k) processor. I was looking to eventually carry over my build to a mITX format, so I was wondering if there were any suggestions towards a motherboard I could purchase.
    I'm looking to use it with a 560 Ti and a 128GB Samsung 830 Pro, so I would require a PCI express slot and SATA 3 connectors. Are there any worthwhile H87 mITX motherboards?
    My budget is fairly flexible, but I'm unlikely to purchase anything more than £90.
    Thanks in advance!
  2. lancer778544
    lancer778544 Multimodder
    5 Jan 2011
  3. Siberdine
    1 Aug 2010
    I'll take a look, thanks very much!
  4. Parge
    16 Jul 2010
    I can't tell what that board really offers over the H81I-Plus?
    Any ideas?
  5. Siberdine
    1 Aug 2010
    All that I've noticed is that it has an extra USB 3 header and uses PCI E 3.0... Is PCI E 3.0 actually a worthwhile thing to have? I imagine it helps with future proofing, but how many times more bandwidth does it support?
  6. lancer778544
    5 Jan 2011
    What Siberdine said plus the H87 has 4x SATA 6Gb/s rather than the 2 on the H81 and the H87 has a couple of extra USB 3.0 ports and an optical port on the back. Whether that's worth the extra £30, I don't really know.
  7. Parge
    16 Jul 2010
    PCIe 3.0 is really only useful if you are running SLI/CFX since that's about the only thing that actually saturates the bandwidth of 2.0.
  8. xaser04
    xaser04 Ba Ba Ba BANANA!
    27 Jun 2008
    My MSI B85i does the job quite nicely with my 4770S. It was just over £50 (seems to be slightly more now?!) and has all the usual gubbins you would expect from a mITX board.
