Watercooling Thinking of watercooling and need a little help
Discussion in 'Hardware' started by barny2767, 26 Feb 2012.
  1. barny2767
    barny2767 What's a Dremel?
    27 Sep 2011
    Ok i have been looking a watercooling for some time and just started looking for a kit or custom set up and dont want to spend to much. somthing around £150.
    Now look at my sig for my rig, I know its in a antek P193 but i dont have much room left and was looking at this http://www.scan.co.uk/products/ek-kit-h3o-120-ltx-basic-water-cooling-kit but dont think i can fit the pump/res in and i cant find any kits that have 5.25 bay res/pumps in them so looking at a custom set up i was looking at somthing like this http://shop.xs-pc.com/xsp/X2O-200-Single-Bay-Reservoir-Pump_25424.html] but it only puts out 200lmp would that cool my CPU or would i need more.
    I would like to only use one 5.25 bay but if the low output of the x20 200 wont keep things cool then i would go for the xspc x20 750 dual bay.
    any help would be good here
    Thanks Barny2767
  2. asura
    asura jack of all trades
    22 Apr 2009
