Planning Thin mitx board for Ivy bridge i5?
Discussion in 'Modding' started by quizz_kid, 9 Aug 2013.
  1. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    Hi.
    I have an Ivy i5 and would like to use it in a very slim SFF build.
    Seems like most slim mSATA boards with external power supply can handle up to 65W TDP, like this board for ex.
    Ivy i5 does 77W TDP.
    Any suggestions?
  2. jrs77
    jrs77 Modder
    17 Feb 2006
    Get an i5-xxxxS/T. They have 65 or 35W TDP.
    The i5-3475S for example has 65W TDP and the HD4000 graphics.
  3. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    The thing is I want to use the i5 3550 I have...
  4. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    I have a 120W 24pin PICO DC supply if that would give me more options?
  5. jrs77
    jrs77 Modder
    17 Feb 2006
    If you've got a 120W picoPSU and the i5-3550 allready, then I'd suggest a standard H77 miniITX-board, which are available for $100. The thin miniITX-boards with onboard-PSU and external powerbrick are all limited to 65W and there's only the boards form intel and Gigabyte.
  6. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    Ok, thanks. But the H77's I've seen have a p4 socket, and my PICO psu lacks of an P4 connector... Is there a way around that? Steal some 12v's from the 24-pin connector somehow maybe?
  7. jrs77
    jrs77 Modder
    17 Feb 2006
    All the desktop intel CPUs require the P4-power-connector. The reason for the thin miniITX not having them visible is the integrated PSU-circuitry.
    So either go with thin miniITX and buy a new CPU with lower TDP or use your current CPU and buy a "normal" miniITX-board in addition to a new picoPSU like the XT150. There's no way to modify your old picoPSU with a P4-connector.
  8. mingingbollock
    mingingbollock Minimodder
    15 Mar 2004
    Why not the P4 connector is only 2x 12v and 2x ground , easily taken from a std molex ?
  9. dullonien
    dullonien Master of the unfinished.
    22 Dec 2005
    World that provide the required power though?
  10. jrs77
    jrs77 Modder
    17 Feb 2006
    Not possible, as it would overload the PSU. The modern picoPSUs have two circuits to prevent this.
  11. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    I'll just get another PicoPSU then, thanks!
  12. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    My friend has a Pico PSU with P4, but it's from molex as this one:
    This won't work?
  13. GuilleAcoustic
    GuilleAcoustic Ook ? Ook !
    26 Nov 2010
  14. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    The thing is I wanted an mITX with onboard power, and they don't support over 65W cpus. But I'm going to get an Intel dh77df and use a pico PSU instead.
  15. GuilleAcoustic
    26 Nov 2010
    Sorry, I gave you the wrong link :
    http://www.gigabyte.com/products/product-page.aspx?pid=4463#sp
    http://www.gigabyte.com/products/product-page.aspx?pid=4462#sp
    These 2 thin ITX boards, with onboard power, both support 77W CPU. Only keep in mind that the PCIe-4x expansion slot is limited to 25W, compared to the 35W with the Intel boards.
  16. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    Oh, that's great news. I'm not going to use the PCIe-4x anyway. I'll go for the GA-B75TN then, thanks a lot Guille!!
  17. GuilleAcoustic
    26 Nov 2010
    You're welcome. The good thing is that this board is less restrictive than the Intel ones about the laptop brick voltage. It accepts anything from 12V to 19V, where the Intel board accept only 19V brick.
  18. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    That's nice, cause I have a 12v brick laying around.
  19. ghostyjack
    ghostyjack What's a Dremel?
    2 Mar 2009
    I've got a Gigabyte GA-H77TH Thin Mini ITX board and according to the website it supports up to 77W chips.
    I can't prove they are right though as I'm running 66W chip.
  20. ghostyjack
    2 Mar 2009
    Looks like GuilleAcoustic beet me to this.
    Oh well, I should learn to read the whole thread before putting in my 2 pence worth.
