2nd 9800gx2 kaput
Discussion in 'bit-tech Folding Team' started by brooksy, 3 Mar 2010.
  1. brooksy
    brooksy What's a Dremel?
    24 Apr 2009
    My second 9800gx2 has died any body had any joy making one good one out of two? Mike
  2. Bork_Bork
    Bork_Bork What's a Dremel?
    26 Apr 2009
    Has one of the GPUs disappeared? Mine did this, I didn't bother to reseat as I assumed it was dead but I tried on Tuesday and it is alive again. It will soon be moving to a much cooler home.
  3. Bork_Bork
    26 Apr 2009
    The resurection was short lived, after constant EUEing I reinstalled the drivers and it has disappeared again.
    Do you have 2 cards that have failed on opposite sides? I've read that the side with the PCI-E connector is is usually the one that fails.
  4. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
    The alternate GPUs on two of my GTX 295s keeps EUEing too. i.e. GPU 0 + 1 will folding happily for days, but 2 + 3 will nearly always EUE part way through a WU.
    Damn Nvidia, and its ECC-less memory controllers and poor quality control :wallbash:
  5. Bork_Bork
    26 Apr 2009
    Faulty GXs seem to go for quite a bit on ebay, especially ones where the card works but has lines across the display.
  6. brooksy
    24 Apr 2009
    One just got low points with the odd EUE then started being recognised as a 8800gt? the other started giving me bsod. The odd thing is that when I swapped a gt250 into one of the slots it started giving EUEs, when it was fine in another PC. Faulty PCI Express slot? The output on the cards was fine. When I have more time I will have another swap around. Mike:wallbash:
  7. brooksy
    24 Apr 2009
    Talking of memory i had one card start giving EUEs then bsod which gave the message of a memory problem, I removed two sticks of memory and it ran ok again. Mike:wallbash:
  8. paddi70
    paddi70 What's a Dremel?
    23 May 2009
    Help,
    Both my Gx2 were producibng the goods last week. But now after running for about 15-20 mins the screen freezes.
    All 4 are detected on FahMON, and Evga percision tool at stratup. Is this heat issue? or something more sinister? :eyebrow:
