Blogs Why I don't use WASD
Discussion in 'Article Discussion' started by Sifter3000, 24 Jun 2010.
  1. Sifter3000
    Sifter3000 I used to be somebody
    11 Jul 2006
  2. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    default setup for me in almost all cases
  3. Leitchy
    Leitchy Minimodder
    5 Oct 2004
    I use the cursor keys, num 0,1,4,5,2, ctrl, shift, return, page down up delete etc. I however have no excuse to not use WASD, and how I came around to using the cursor keys? Who knows!
  4. yakyb
    yakyb i hate the person above me
    10 Oct 2006
    depending on the game i some times like to bind [F] to Grenade
    but other than than default generally
  5. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
    I used to used the Cursor Keys until quite recently. I think the last game I played that way was the original FEAR when it was released - WASD just didn't seem sensible to me. I only changed when I was bullied into it by friends.
    The reason I stayed with cursor controls was simply that, when I first got into 3D shooters, namely Quake, the default controls were Cursors, plus PG-Up and PG-Dn for looking up and down. I just wasn't comfortable using mouselook for starters.
    Later, when I had started to use the mouse, I still stayed with the Cursors for movement, then Ctrl for duck, Num-0 for Use, Shift for Jump and End for reload. That was mainly because I'm very clumsy and I have very big hands - I don't need to stretch to reach those keys and the gap means I didn't fumble.
    Nowadays though, I'm just a vanilla WASDer.
  6. Jamie
    Jamie ex-Bit-Tech code junkie
    12 Mar 2001
    I use a PS3 controller.
  7. Bob1234
    Bob1234 What's a Dremel?
    30 Jul 2008
    Back in the early days, this being Doom/Quake, before mouse look, I used to use the numpad 8462 to move, space to jump, A to fire and SD to strafe left and right.
    Worked wonders, also gave you complete use of both hands for the keyboard.
    Curse you mouse look!!
  8. isaac12345
    isaac12345 What's a Dremel?
    20 Jul 2008
    About 5 years ago, I used to play Unreal Tournament with the cursor keys. But I changed to WASD when one day I lost really badly in a Counter Strike Tournament and felt quite embarassed about it.
    I might just try your control scheme, Paul, to see how it feels.
  9. Teelzebub
    27 Nov 2009
    I always set the A to the C and the shift to the R just find it more comfortable that way.
  10. Bungletron
    Bungletron Minimodder
    25 May 2010
    One of my old school friends played like this on Quake and was epically good at deathmatch, again roughly the same reason (we used to play Doom and I believe that cursor keys was the default setup, but I am certain that by the time Quake rocked up WASD was also bound by default, I have certainly been WASD since Quake). Weird thing was he was right handed but played with a normal MS intellimouse southpaw, a bit like the Hendrix of Quake, very odd.
  11. [USRF]Obiwan
    [USRF]Obiwan What's a Dremel?
    9 Apr 2003
    I use the cursor keys, num 0, 1,4 num 0,1,4,5,2, ctrl, shift, return, page down up delete, home and end. The reason for this, I'm lefthanded, my mouse is on the left side of keyboard. AND in the yesteryears all the arcade joysticks where left handed and buttons right handed. So kinda taken over from that
  12. RTT
    RTT #parp
    12 Mar 2001
    FIFY :thumb:
  13. CardJoe
    3 Apr 2007
    I hate you I hate you I hate you.
  14. bpdlr
    bpdlr High-frequency bogon emitter
    22 Sep 2009
    A guy once applied to join a guild I was in (I think it was for Aion?). He said he'd lost an arm in an accident but had taught himself to use just one hand to control games, and was adamant that he'd got to the stage where most people didn't notice his disability in-game. It's amazing how the human body can adapt.
  15. Fizzl
    Fizzl What's a Dremel?
    9 Jun 2009
    I used to be an ESDF man (means your hand sits on the home keys and you have more buttons in reach). Right click to jump, space to crouch (makes duck jumping and crouching endlessly behind cover easier). I have these because I started playing FPS before WASD was the norm (and think it's a better setup).
    However these days I have a Belkin n52te and a g9 so rather than remapping my keys for every games I have the controller and mouse button positions moved to convert the standard WASD to how I like it.
  16. Zoon
    Zoon Hunting Wabbits since the 80s
    12 Mar 2001
    I actually use ESDF myself even today. This harks backs to Tribes, which defaulted to ESDF.
    Its not hard to transition to the right by one key, and it gives you a whole other set of useful keys around it.
    I jump on my mouse side button, reload on scroll click, and W and R become lean, where the developers bother to implement it these days. A is usually to activate zoom, and space to crouch.
  17. Cabe6403
    Cabe6403 Supreme Commander
    3 Apr 2007
    I use WASD but I tend to customise the key surrounding it away from defaults to my own settings depending on the game
  18. yakyb
    10 Oct 2006
    anyone use a nostromo or similar?
  19. impar
    impar Minimodder
    24 Nov 2006
    Greetings!
    Movement - Cursor Keys
    Fire - LMB
    AltFire - MB4 (aka mouse back button)
    Jump - RMB
    Duck - RCtrl
    Run - RShift
    Use - Enter
    Reload - BackSpace
    Melee - Num 1
    FlashLight - Num 0
    Talk - End
    Grenades/Special Moves - Insert/Home/PgUp/PgDown/Delete
  20. Narishma
    Narishma What's a Dremel?
    21 Feb 2008
    Have you ever thought about switching the mouse and keyboard? Since you seem to have trouble only with some fingers on your left hand, using the mouse with that hand would free the other one to use whatever key layout you'd like.
Tags: Add Tags
