Motherboards Asus mobo what has the most sata ports?
Discussion in 'Hardware' started by REDDEVIL-UK1, 16 Jun 2010.
  1. REDDEVIL-UK1
    REDDEVIL-UK1 MUFC
    17 Feb 2010
    i'm looking for a new Asus motherboard socket AM3 ideally with 4+ 3pin fan connections and more than 4 sata ports and 4 ram dimms (not two) for roughly £40-£100
    if asus don't have any good ones i might go the gigabyte route
    does anyone have any good boards that qualify??
    thanks
    REDDEVIL-UK1
    :thumb:
  2. murraynt
    murraynt Modder
    6 Jun 2009
    Its me again
    All the new boards will usually have 6 sata connections i would recommend a Msi c-45 or G-45 retailing at about 40 pound on the high end you can get an Asus M4A89GTD PRO/USB 3 at 115 pounds
  3. REDDEVIL-UK1
    REDDEVIL-UK1 MUFC
    17 Feb 2010
    hi me again also lol
    thanks check em out now :)
  4. REDDEVIL-UK1
    REDDEVIL-UK1 MUFC
    17 Feb 2010
    have you got the full name for the msi ones can't find em on ebay
  5. REDDEVIL-UK1
    REDDEVIL-UK1 MUFC
    17 Feb 2010
    the Asus M4A89GTD that's got th890GX chipset hasn't it so it'll take a 6 core cpu won't it??
  6. murraynt
    murraynt Modder
    6 Jun 2009
  7. murraynt
    murraynt Modder
    6 Jun 2009
    Oh wait them prices were in euro sorry only slightly over priced now
  8. REDDEVIL-UK1
    REDDEVIL-UK1 MUFC
    17 Feb 2010
    any from gigabyte you'd recommend?? (same avg price though) and poss SLI too
  9. murraynt
    murraynt Modder
    6 Jun 2009
    can't think of any.The C45 and G45 are both excellent boards though, they wer recommended by custom pc and bit tech.i have one in my little brothers pc and overclocks to 3.7 ghz
  10. REDDEVIL-UK1
    REDDEVIL-UK1 MUFC
    17 Feb 2010
    i lie the look of the C45 board black and blue combo it'll go well with my black case and some blue leds try and get a blue fan controller that'll look cool (no pun intended lol)
    cheers again have a good night murraynt :)
  11. murraynt
    murraynt Modder
    6 Jun 2009
    Thats the reason i went for the G45 instead of the C45 even though it doesn't have a clear side :confused:,no problem hope all go's well
  12. REDDEVIL-UK1
    REDDEVIL-UK1 MUFC
    17 Feb 2010
    sorry is the C45 the one that has a vrm heatsink with DR.MOS on it or is that a diff one??
  13. murraynt
    murraynt Modder
    6 Jun 2009
    The C45 is the slightly cheaper one with red pcb, where as the G45 has crossfire and is blue and black, the one with heatsinks and dr.mos is the much more expensive ASUS board
  14. REDDEVIL-UK1
    REDDEVIL-UK1 MUFC
    17 Feb 2010
    so is the MSI mobo available on the am2 /+ am3 platform??
  15. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    Just a poke Dr. Mos is a MSI thing I believe, not Asus...
  16. murraynt
    murraynt Modder
    6 Jun 2009
    oh i thought it was for all boards,do you know exactally what it does?
  17. Bloody_Pete
    11 Aug 2008
    It's just there take on power management, I think its EPU on Asus boards. Just saves power mostly, very little difference, double so if your overclocking.
  18. murraynt
    murraynt Modder
    6 Jun 2009
    oh ok i see,Thanks
  19. REDDEVIL-UK1
    REDDEVIL-UK1 MUFC
    17 Feb 2010
    so erm is it available on the am2 /+ /am3 socket?? :)
  20. murraynt
    murraynt Modder
    6 Jun 2009
    go for the am3 socket,am3 socket supports ddr3 ram and is more future proof, you can post a link so i check if you want
