Modding Water Cooling Design
Discussion in 'Modding' started by Ddemon, 10 Jan 2013.
  1. Ddemon
    Ddemon What's a Dremel?
    7 Dec 2009
    Hi all, been planning this loop for a few years now, bought most of the stuff then ran out of money. Anyway trying to get it finished now, iv done a design on sketchup approximately where everything will go (im not the best) and wanted your opinions. Note that the NB SB and pwms will be in one of the loops.
    Originally i had 2 graphics cards thats why there are 2 loops, so i thought i would keep them for when i get another 570.
    Anyway, my plan is to build a small enclosure out of plexiglass ( already bought it ) iv got 4 500x500mm sheets 8mm, but the problem im having is if it will support the rest of the computer?
    Iv thought about putting the enclosure on top but then im unsure if the pumps will work effectively being above the waterblocks?
    Hardware :
    XFX 790i Ultra
    Q9550 @ 3.8
    Gainward GTX570 Phantom
  2. The_Crapman
    5 Dec 2011
    I think it would support the whole case no. you'd probably have to put in a support frame.
  3. Ddemon
    7 Dec 2009
    Im trying to think of ways to support it. One idea is angle iron on the inside or outside and tap/bolt the plexi to it.
    Does anyone have any better ideas?
  4. jrs77
    jrs77 Modder
    17 Feb 2006
    Build a box out of 6mm HDF (high density fibreboard). Way easier to work with, if you don't have any special tools, and it's dirt cheap aswell. You can buy 1m² of 6mm HDF for some €20.
  5. Ddemon
    7 Dec 2009
    I already have the plexiglass, just need to think of a way to strengthen it.
  6. alpaca
    alpaca llama eats dremel
    27 Jan 2009
    put some ribs against the plexi then? 8 mm plexi is not that weak, and if its strengthened by plexi 90 degrees on the walls, it'll be that much stronger.
    top side view:
    |- RADIATOR -|
    |- PUMPS -|
    |- RADIATOR -|
    with the minus sign glued against the wall, so to reinforce it. effectively making the plexi much thicker.
    Edit: this is not clear, isn't it?
  7. Ddemon
    7 Dec 2009
    What do you mean? Bend some plexi into 90' and fix it to the case on the joints?
  8. alpaca
    27 Jan 2009
    Ok, I made a quick-quick sketchup of what i meant. This way, the side is much stronger than without the ribs. And with some imagination, the ribs could be built in in the design. (to hold your radiators etc)
  9. jrs77
    jrs77 Modder
    17 Feb 2006
    I thought you were only going to build the reservoirs out of the plexi.
    Anyways, 8mm plexi doesn't need any reinforcement. The material is strong enough to carry the weight of the case ontop, if you build a box out of it. You just need to make sure that the joints are strong enough, and I would recommend using brass-inserts and screws to join the panels, as I'm not too confident with glue.
  10. Ddemon
    7 Dec 2009
    I see what you mean now.
    Good idea, but i cannot see how i could implement it and still have the radiators mounted where they are.
    I could use the idea and make a U shape and have the hoses running up them;
    Top View
    _____________________
    l...................__...................l
    l...................O l...................l (dots dont represent anything, wouldnt work otherwise)
    l..................O_l...................l
    l_____________________l
    Another problem im having is how to mount the reservoirs. Id like to use the threaded holes in the sides, the only way i can think is drill a hole in the side and have a long bolt. Ill need to take it out to put water in. My plan was to cut a hole in the back panel and put a fan grill there or something.
    Thanks for help btw.
  11. Ddemon
    7 Dec 2009
    No, need to build the whole bottom box. Oh, brilliant, saves a lot of work for me.
    Iv been told by my friend that the glue is the business as his friends make fish tanks using it and such. Can anyone else vouch? Id prefer using the inserts to be honest as it allows me to take a panel off if needed.
  12. bulldogjeff
    2 Mar 2010
    Back to your pump question. It doesn't matter where it is in relation to the GPUs. More importantly is it is below the reservoir. Reason being that it will be a bugger to primer the system and you also run the risk of the pump running dry.
