Hardware Corsair H110i GT Review
Discussion in 'Article Discussion' started by Dogbert666, 10 Feb 2015.
  1. Dogbert666
    Dogbert666 *Fewer Lover of bit-tech Administrator
    17 Jan 2010
  2. David
    7 Apr 2009
    One (purely cosmetic) irritation I would've hoped to see resolved is the ability to change the orientation of the Corsair logo on the pump block - a removable logo cap over the LED or something shouldn't be that hard to do.
  3. Baz
    Baz I work for Corsair
    13 Jan 2005
    That is....actually a really good suggestion Spreadie. Will pass that on to the cooling PM here at Corsair.
  4. David
    7 Apr 2009
    I don't have a window on my case but, if I did, it'd do my head in...
  5. Maki role
    Maki role Dale you're on a roll... Lover of bit-tech
    9 Jan 2012
    Inb4 nothing happens just like with the suggestion to have different anodized versions of the dominator platinum lightbar kit...
  6. Baz
    13 Jan 2005
    products take months to dev. We showed off an orange dominator lightbar at CES, so they're in the works.
  7. Redbeard
    Redbeard What's a Dremel?
    27 Jul 2009
    I'm the cooling PM at Corsair. Your suggestion is noted and will be kept in mind for future iterations of the products.
    Thanks.
  8. Shirty
    18 Apr 1982
    But do you have a red beard? That's the burning question.
  9. Chicken76
    Chicken76 Minimodder
    10 Nov 2009
    Who manufactures these, CoolIT or Asetek?
  10. jinq-sea
    15 Oct 2012
    Oh that's really aggravated my OCD haha!
  11. Baz
    13 Jan 2005
    See? We're always watching!
  12. SchizoFrog
    SchizoFrog What's a Dremel?
    5 May 2009
    I agree with Spreadie's suggestion. Personally I think a logo cap would be great for the whole product lines that way end users can decide whether to go with Corsair (Sails + orientation) or Corsair Gaming (Tattoo + orientation). Surely then everyone is a winner??
    It is a shame that these can't simply add in a GPU block to the loop as I am sure it would handle the heat with ease.
    EDIT: On further inspection of images here and elsewhere I have to say that I am not a fan of all the cables. Can the electronics on hidden within or alongside one of the cooling tubes with cables or connectors coming from the rad or at least around that area? That would seem to tidy up the area directly around the CPU block, which aesthetically is quite important, I believe.
  13. Charlbotha
    Charlbotha What's a Dremel?
    10 Nov 2014
    I do like this cooler, does anybody know if it will fit in a corsair 330R? I know the technical specs of the case says that it has 280mm radiator mounting holes, but I am not sure if there will be enough clearance between the fans and the 5.25" drive bays. Can anyone please assist?
  14. RedFlames
    23 Apr 2009
    It should [it'd be a bit daft if it didn't fit in corsair's own cases], though you may need to put the tubing at the other end [and possibly have to remove the rear 120mm]...
    It does look like it'd be a tight fit...
  15. Parge
    16 Jul 2010
    You can’t just ask for a company to make a product and then make sarcastic remarks about it not being done. Fortunately the Corsair boys here are consummate professionals and answered you politely, despite your tone. :sigh:
  16. Wazza
    Wazza What's a Dremel?
    23 Jul 2011
    CoolIT make them.
    Mine arrives tomorrow! :thumb:
    Chicken76 likes this.
  17. LeMaltor
    LeMaltor >^_^
    3 Oct 2003
  18. adrock
    adrock Caninus Nervous Rex
    5 Dec 2006
    for anyone looking, i've been struggling to find one of these for a while but novatech should have a couple; i pre-ordered and they had a dozen coming in, now they're showing as in stock.
    can the SP140L fans be bought separately for running push pull? Can anyone tell me how different from standard SP140 fans are they? It'll be cooling the CPU and exhausting up through the roof of a corsair 540.
Tags: Add Tags
