Case Mod - In Progress Corsair Carbide MbK
Discussion in 'Project Logs' started by kier, 26 Aug 2013.
  1. kier
    kier -----------------
    1 Mar 2011
    Hi my fellow casemodders...it's Kier again
    It's time for a new build with the beautiful Corsair Carbide Air 540.
    Saw this case for the first time at some pictures from Computex 2013. And think it has a lot of potential
    A good looking case with numerous possibilities for air cooling and watercooling ofcourse.
    Time to think of some nice ideas and cut it in pieces.
    Still have some hardware laying around for this build, which of course may change in the future of the build.
    Hardware:
    Mobo: Z68X-UD4-B3
    CPU: i7 2600K
    GPU: GTX680 x2
    PSU: CM silent pro Platinum 1000w
    Fans: xigmatek xof-f1251 6x
    SSD: OCZ Vertex2 120GB
    HDD: WD Green power 1TB
    RAM: Corsair Dominators 8GB1600C7
    Watercooling:
    Radiators: EK-CoolStream RAD XT (240) + EK-CoolStream RAD XT (360)
    GPU blocks: EK-FC680 GTX+ - Acetal+Nickel 2x
    CPU blosk: EK-Supremacy (old style)
    Pump: Laing DDC-1Plus MCP355 + EKWB top
    Tubes: Acrylic tubes 12/10mm
    And a lot of BP and EKWB fittings
    First of al some pics and a small review of the case.... The Corsair Carbide Air 540.
    And here it is.
    Dimension: 415mm x 332mm x 458mm
    Material: Steel and plastic
    Beautiful full side panel window
    Front I/O:
    (x2) USB 3.0
    (x1) Headphone
    (x1) Mic
    Removable front dust filter.
    Top
    There is space for 2 x 140mm or 2 x 120mm fans or ofcourse a radiator
    Filter
    With magnets
    Front space for 2 x 140mm, 3 x 120mm fan or also a radiator
    3x AF140L 140mm fans included
    Inside
    The two AF140L 140mm fans
    CPU cutout
    And the 3e included AF140L 140mm fan
    8 expansion Slots
    Dual 3.5” hot swap bays
    4x 2.5” tool-free SSD drive cages
    5.25" drive bay
    Cable routing cutouts with rubber grommets
    All necessary cables present
    Maximum PSU length 200mm
    Accessory kit
    Time to place some hardware and see how it looks
    Maximum GPU Length 320mm
    If your going for air...Maximum CPU Cooler Height 170mm
    More to come!!!
  2. Kovoet
    Kovoet What's a Dremel?
    26 Aug 2009
    Damn you kier just as I'm getting one you going to make me feel inadequate. I'm sure you will do an awesome job as usual, cannot wait.
  3. kier
    1 Mar 2011
    First post wasn't much about modding, so time for a little modding UPDATE!!!
    This time i'm gonna cut the case in half ;)
    First job...place some nice Xigmatek xof-f1251 fans. Btw. The color combination will be black/ grey and white.
    First, see how it looks
    A bit "normal". So other idea then, but first disassembling the case .
    Once stripped, this is whats left.
    Marked the size of 3 Xigmatek fans on top
    Time to do the first cut.
    Cut 2 strips to the right size and cut/ file some fan shapes
    Mounted and tried to get the same height as the original plastic covers
    Placed a 240 rad beneath it. 1 fan is for the show, much better looking then 2 on top and three in the front
    Both rads placed like this
    Again same heights as the plastic covers
    And front
    Cut a acrylic plate and made 3 fanholes in it
    And again for the front
    Cut 5mm on both sides to get a nice opening between the acrylic and plastic
    Glued a angled piece between (with ACRIFIX 192)
    And here it is...the new cover
    First pasted white vinyl on it to get a better light distribution from some LED strips
    Placed some white LED strips and a line of frosted acrylic on both sides.
    After this pasted another layer of vinyl, but this time black and put some power on the strips
    Hmm, stupid me...have a lot of RGB strips and controllers laying around.
    So removed the white strips and placed RGB.
    Dont think i'm gonna use the different colors a lot, but it's funny so why not?
    Dim the white lights
    And full power
    finally... a nice movie
    Pranja likes this.
  4. Kovoet
    26 Aug 2009
    WOW looks already GVD
  5. Shurika
    Shurika Minimodder
    9 Mar 2012
    Exellent as usual! Can't wait for continue
  6. kier
    1 Mar 2011
    Thanks :thumb:
  7. WaRn00b™
    WaRn00b™ bit-tech addict
    14 Jan 2013
    Wow... that looks epic already!! Subbed. :thumb:
  8. Pierre3400
    Pierre3400 What's a Dremel?
    22 Aug 2013
    Ever since i learnt about this case, i have had wet dreams about modding one.
    Looking at this, only makes me want to do it even more!
    That looks simply amazing, i love the way you took those fans. Its looks so perfect with the LED's and everything.
  9. stuartwood89
    20 Aug 2008
    Watching this one!
  10. damien c
    damien c Mad FPS Gamer
    31 Aug 2010
    Subbed!
  11. Jezzafool
    Jezzafool What's a Dremel?
    2 Sep 2011
    That looks fantastic!
  12. kenco_uk
    28 Nov 2003
    Subbed, always love your mods kier.
  13. AlienwareAndy
    AlienwareAndy What's a Dremel?
    7 Dec 2009
    HOLY FUUUUUUUUU........
  14. Gentleman_Dingo
    Gentleman_Dingo What's a Dremel?
    30 Aug 2007
    Kier builds are always entertaining to read. Subscribed yet again.
  15. whyte
    whyte What's a Dremel?
    27 Mar 2012
    I love this case... Ive been dying to see what can be made of it by someone with Kier's skill and style.
  16. Z0DIAX
    Z0DIAX bending alloys
    26 Jul 2013
    seriously subbed , I love this case, and in the hands of Kier it can only get better
  17. kier
    1 Mar 2011
    Thanks :thumb:
    Mod one mate, you will ike it very much :D
    :clap:
    :thumb:
    :hip:
    Thanks mate
    ...CK :D
    :lol: Thanks :lol:
    Kier style it will be ;)
    Hope so, but think i will not disappoint you :p
  18. Dave2010_TA
    Dave2010_TA Minimodder
    25 Feb 2012
    Mmm another build by Kier...MUST WATCH OVER ahahah, I follow you mate
  19. kier
    1 Mar 2011
    Update!!!
    External is almost finished.... So let's go inside
    What I did:
    Cut a acrylic midplate, and a acrylic mobo tray cut out with the dimensions of what remains after placing the mobo.
    Cut/ placed 2x angled aluminum strips which are bent. Placed at the side from the vertical radiator and front midplate.
    I also placed an acrylic pipe at each radiator which later become linked.
    Height midplate is sufficient to do some installation work beneath it.
    Attempt number 1 in terms of the tube routing (off course straight forward)
    Nice ... but not quite the thing i'm looking for. So change of plans:
    GPUs in-and outlets all down and later.... in-and outlet CPU up
    With C47 adapters
    Made all covers and midplate ​​black again
    Only need to think/ make a nice cover for the horizontal rad
    Connect the GPUs
    Underneath the case I have some space to connect everything (needs to be nicely finished) Rads (right) connected and has a drain port.
    Furthermore GPU1 GPU2 coupled and the other in-and outlet with high flow fittings / flex tubes going to the right side of the case.
    And screwed an acrylic plate against it.
    CPU / outlet goes up and used some 90 degrees Rotery's to let it go to the right compartment
    Looks quite clean allready
    The CPU connection comes out here and using fillports
    As for the reservoir.... I have found a old EK Bayres. Made a new frontplate, ​​this time without EK logo
    And placed a MCP355 pump at the back
    Fillports from both rads
    And two pics of the beautiful fans and nostalgic bayreservoir
    To be continued!!!
    montymole likes this.
  20. stuartwood89
    20 Aug 2008
    Tubing looks awesome. Would love to be able to pull that off.
