hi everyone, i have been trying to fold with 2 gpus this morning but i cant seem to figure out how to add the second one on to fah7, i know to go to advanced setting-slots-add-gpu but it says something like there is no other gpu on system, both cards work in 1st pci-ex slot but neither in second. im running my signature below plus a gtx570 any help would be great ross
Hi ross, The V7 client shud auto detect the gpu's, but mine wouldn't fold I switched to GPU tracker and it worked fine HTH
Hi Ross2011 First off, what OS are you using? When you fit the second card and switch on the PC does Windows find the card and install drivers? If you open Nvidia control panel does it show both cards?
