Electronics Replace relay with transistors
Discussion in 'Modding' started by jazzzyj, 23 Feb 2013.
  1. jazzzyj
    jazzzyj Minimodder
    2 Apr 2002
    Hi guys.
    I have a need for this following circuit, but it currently uses a automotive relay. I want to make it solid state, and so also quite a bit smaller.
    The 12 volt source from the left is controlled by a switch. This is driving a solenoid on the right. The square box. Solenoid has dual coils, one to "open" it (black connection), then the other to "hold" it (green connection).
    The circuit creates a pulse for 1-2 seconds to the black wire then leaves the green wire to take over. When the 12 volts is removed from the left, the circuit resets.
    Is anyone able to have a look and re-draw it to use a transistor/Mosfet instead please?
    Thanks!
    -J
  2. theshadow2001
    3 May 2012
    Any time ive used a solid state relay it has just had two terminals which were wired in the same manner as a regular relay. Obviously using just a mosfet would require a slight modification to the circuit.
  3. jazzzyj
    jazzzyj Minimodder
    2 Apr 2002
    I used to know about electronics, but my powers have escaped me.
    I'm sure it is simple, but I don't know how to do it.
    -J
  4. Boscoe
    Boscoe Electronics extraordinaire.
    5 Jan 2010
    I wish I could help but I only have an iPhone or iPad this weekend!
  5. ferret141
    ferret141 Minimodder
    18 Oct 2010
    Paint it?
  6. jazzzyj
    jazzzyj Minimodder
    2 Apr 2002
    Its ok, its not a rush. Need it soon but it will wait til after the weekend!
    Thanks guys.
    -J
  7. ShinyAli
    ShinyAli What's a Dremel?
    14 Sep 2012
  8. jazzzyj
    jazzzyj Minimodder
    2 Apr 2002
    Na, want to do it properly.
    -J
  9. feedayeen
    feedayeen What's a Dremel?
    18 Jun 2008
  10. jazzzyj
    jazzzyj Minimodder
    2 Apr 2002
    Will a SSR react in the same way as a normal relay?
    The circuit I posted uses a cap to hold the pulse for a few seconds.
    I would rather use a transistor as it would be smaller than a SSR wouldn't it?
    -J
  11. Boscoe
    5 Jan 2010
    Why use an expensive SSR which is overkill. Just use transistors in emitter follower, I will draw it tonight when I get my comp.
  12. Boscoe
    5 Jan 2010
    What currents will you expect with the relay? I assume its 12VDC?
  13. jazzzyj
    jazzzyj Minimodder
    2 Apr 2002
    Yes it's 12vdc. The momentary pulse will pull about 2.5 amps apparently.
    Thanks!
    -J
  14. Boscoe
    5 Jan 2010
    And the longer one?
  15. Boscoe
    5 Jan 2010
    Looking at it now I don't really understand your drawing. Here is a transistor 'switch' attached. L1 symbolizes your solenoid. attach the base of Q9 to anything above 1.5V refrence to GND and current will flow through L1 or whatever you put in L1's place. Q7 may need a small heatsink depending how long they are on with 2.5A running through it, 2.5A is really the max I would go on this. If you use a resistive or capacitive load in place of L1 you can drop D1. The solenoid is inductive so you must keep D1.
    Give me some more info and I'll see what I can do. Hope this helps.
  16. jazzzyj
    jazzzyj Minimodder
    2 Apr 2002
    Thanks for that, but yes, I think you might have mis-understood the drawing.
    I have 2 coils.
    They share a common +12v supply.
    Coil 1 is a light draw coil and does not draw much current at all.
    Coil 2 is a heavy draw coil at about 2.5 amps.
    How the circuit should work:
    +12v is switched on.
    Both coils should energise.
    2 seconds elapse.
    Coil 2 de-energises.
    Coil 1 remains energised.
    +12v is switched off.
    Coil 1 de-energises.
    I hope that helps.
    -J
  17. Boscoe
    5 Jan 2010
    Okay I'll draw something tonight.
  18. jazzzyj
    jazzzyj Minimodder
    2 Apr 2002
    Cool. Thanks again.
  19. jazzzyj
    jazzzyj Minimodder
    2 Apr 2002
    Any luck?
    -J
  20. Boscoe
    5 Jan 2010
    Sorry I've been out a lot, give me 24hrs!
