Motherboards Fried motherboard...
Discussion in 'Tech Support' started by mr.a2008, 29 Jun 2013.
  1. mr.a2008
    mr.a2008 What's a Dremel?
    3 Aug 2009
    Hey guys,
    Another issue with my computer (spec in sig).
    Right the other day I have tried to turn my computer on after taking out an replacing the Wi-fi PCI card due to a slight issues with not being recognised by Win8, which normally works in restoring the connectivity but not this time.
    Initially I thought it could be a graphics issue, don't know what lead me down that road really. After taking the newish card 560Ti out and replacing it with the old 8600 to see if that worked or not (obviously not hence the thread here). Just trying to see if anyone has any ideas that could try and revive this mobo which has done me well over the years, would be great if I could.
    Otherwise I am going to have to look for a new Mobo, CPU/APU, with some RAM as well, I haven't kept up with the times recently so I am looking for a new but cheapish build for the 3. Due to tightened budget (car is eating the money at the moment).
    So yeah, thanks guy!
    Mr.A
  2. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    Put it in a preheated (~200C) oven for 5 or 6 minutes. Make sure to remove anything you can like heatsinks and labels etc
    mr.a2008 likes this.
  3. AlienwareAndy
    AlienwareAndy What's a Dremel?
    7 Dec 2009
    And cover any polymer caps as they can expand.
  4. mr.a2008
    3 Aug 2009
    Cover with what though? I have never reformed anything before.
    Thanks for the advice guys
  5. Teelzebub
    27 Nov 2009
    Cooking foil
  6. goldstar0011
    goldstar0011 Multimodder
    2 Sep 2007
    Sorry but when I read the title i was thinking you deep fried your motherboard:lol:
  7. Votick
    Votick My CPU's hot but my core runs cold.
    21 May 2009
    Same LOL :D
  8. erratum1
    erratum1 What's a Dremel?
    30 Apr 2009
    What could you have done just by removing and putting back a pci card? Static?
  9. mr.a2008
    3 Aug 2009
    Don't know, still wouldn't post. Even changing GPUs and removing PCI cards. So I don't really know. Any suggestions to what I have done I am all ears really.
    If this doesn't work then I will be looking to get new parts to replace the Mobo, RAM and CPU. What would you guys recommend? Budget £350.
  10. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    No post boot beeps ? fans not spinning up ?
  11. mr.a2008
    3 Aug 2009
    Got it working again! Just baked it for 20 minutes in the oven, worked a treat. Thanks guys!
  12. Corky42
    30 Oct 2012
    From fried to baked :D
    You need to write a cookbook.
    Nice to hear its working again. :thumb:
