Case Mod - In Progress StarCraft II: Protoss [CM Cosmos] - Nearly completed
Discussion in 'Project Logs' started by Koradhil, 22 Oct 2007.
  1. Koradhil
    Koradhil What's a Dremel?
    9 Nov 2004
    After a couple months of waiting for the new Cooler Master case, I finally got it. I personally went to pick up a Cosmos at Cooler Master's European office in Venlo, The Netherlands. I was lucky because it was the only one not reserved for shops or distributors. This mod will be a quick one, as I want to have it finished before the Benelux Casemod League on November 23 - 25. Sponsors are Cooler Master and A.C. Ryan.
    [​IMG] [​IMG]
    The theme for the mod is StarCraft II which will be coming out in 2008. More specifically, I chose to do the mod in the style of Protoss, one of the races in the game. Much of my inspiration comes from this picture:
    I started by stripping the entire case to the bare frame.
    This afternoon I had some time to pick up some spraypaint at the local car tuning shop. I picked Motip #43250 (yellow/sand) and #44925 (blue) to be the main colors for the case. I started with the basecoat.
    Followed by three layers of yellow.
    Quick mockup to see how it turns out. The parts still need to be varnished.
    Ok thats it for now, tomorrow I'll do some more.
  2. Silent_Enigma
    Silent_Enigma What's a Dremel?
    28 Sep 2006
    This can be good, i will follow this.
    Keep it up !!!
  3. brinkz0r
    brinkz0r Minimodder
    15 Dec 2006
    Ah there it is, I've been looking forward to this one :) You're gonna have a hard time to finish it in time, but I wish you the best of luck!
  4. Koradhil
    9 Nov 2004
    I've done it before (Gemini in 4 weeks), I can do it again ;)
  5. teamtd11
    teamtd11 *Custom User Title*
    31 Aug 2005
    Looks like a very nice idea, im a big starcraft fan. so im hoping this turns out well. Good luck:thumb:
  6. sik19
    sik19 What's a Dremel?
    2 Jan 2006
    Nice, the typical protoss yellow frame. I will definetly watch this mod :clap:
  7. 500mph
    500mph The Right man in the Wrong place
    22 Jun 2007
    looks to be an eye catcher. i'll have my eye on this
  8. TNash
    TNash What's a Dremel?
    12 Mar 2007
    I like the contrast between the yellow and is that brushed aluminum? Looks cool.
  9. Spaceraver
    Spaceraver Ultralurker
    19 Jan 2006
    Subscribed...
  10. Koradhil
    9 Nov 2004
    Its not going to be brushed aluminum in the end, it will be yellow as well.
  11. Godric
    Godric What's a Dremel?
    23 Jan 2007
    Nice project, I wonder what you will make of it :)
    Good luck making tBCL finals, I think I will visit so maybe I will see it in real-life.
  12. HeXeN
    HeXeN Straight from Hell
    14 May 2006
    Alu works well with almost everything ;P even with brushed allu :D. But Are U thinking about cool blue acrylic parts inside :>? (i'm just curious) (And next one mod from U, i'm waiting for updates)
  13. Stuey
    Stuey You will be defenestrated!
    20 Jan 2005
    I agree, the brushed alum and yellow accent look good together, even though you plan on painting the alum later on.
  14. Koradhil
    9 Nov 2004
    Thanks people. Yes HeXeN, there will be lots of blue inside and I got two MeshX Hexx panels from A.C. Ryan as well as a Hexx radgrill ;)
    Now I need your opinions on this matter. I want to paint the sidepanels, but do you think I should pick a different shade of yellow for that, or will the same color be fine ? Same color is more economical (saves me another spraycan), but it might be a bit too much of the same otherwise. There will be a window in the left panel and I'm thinking of doing a SC2 logo on the other (not sure though), so it will not be an entirely yellow panel.
    And another question on the paint. I was thinking of painting the top panel of the case blue, but I'm not sure this will look very good. Do you think I should spray it yellow also and paint only the 'grill' at the back blue ?
  15. Stievius
    Stievius Industrial Design Student
    12 Nov 2006
    I would go for a slightly darker yellow -on the side panels- if I were you ;)
  16. splashdream
    splashdream What's a Dremel?
    9 Jul 2003
    For the side panel color a nice sandstone(orange-brown-beige) color would provide a nice tie in to the colors in the image you are basing this case upon.
  17. Thadeez
    Thadeez What's a Dremel?
    20 Dec 2005
    Why not try something else, to simulate the hexagonal effect of the dome in the picture. Like, laying down a background of the light blue on the sidepanel. Then, put a Hexxpanel on top of it and lightly spray some of that nice purple over it. The hexxpanel will leave it's footprint on there in light blue and voilá, you got it :)
  18. Koradhil
    9 Nov 2004
    Thanks for the advice people. That hex spray effect is a really good idea, I will think about it.
  19. coolmiester
    coolmiester Coolermaster Legend
    31 Dec 2002
    Great start and a great theme Koradhil - looking forward to future updates.
    How are you finding the COSMOS??
  20. Koradhil
    9 Nov 2004
    It's definately one of the best cases I have ever worked with. I'd personally rather buy a Cosmos than a Silverstone TJ07.. (I have both) The Cosmos just has the best features, I absolutely love the sidepanel mounting system. The design remains to be a matter of taste though, I can understand why some don't like the case.
