Other Share your TWEAKS
Discussion in 'Software' started by knuck, 11 Mar 2008.
  1. knuck
    knuck Hate your face
    25 Jan 2002
    ... of all kind !
    Let's make this thread a tweak sharing center where we can offer or ask for windows/linux/games tweaks of any kind :)
    Remember, it doesn't have to be fancy or complicated, a simple but useful tweak is more than welcomed :D
    I'll start with something simple.
    On every single new Windows XP installation that I do (and I do lots of them, virtual and physical) I remove all the icons on the desktop. This includes the Recycle Bin which I think is completely useless. To do so, I simply install Tweak UI for XP. It takes about 5secs to install (right click on the ini, then install) and it can, among other things, remove the Recycle Bin without the need to reboot !
    Okay it was a simple one but you guys and girls are free to share yours !
  2. 500mph
    500mph The Right man in the Wrong place
    22 Jun 2007
    Start> All Programs Lag Fix
    Tired of waiting a second or two for your Programs list in your Start menu to pop up?
    Simple, Just run RegEdit ( Start>Run>"regedit"). Navigate to HKEY_CURRENT_USER\Control Panel\Desktop. Double-click on MenuShowDelay in the right hand panel, and change the value from 400 to 5.
    Reboot and enjoy!
    Or set it to 10000 to play pranks on your friends that don't click it
    /On Topic
    When I do fresh Installs I delete the Recycle Bin using Regedit. I don't mind the reboot(Sometimes I don't have to). I would rather reboot than install software.
    Tweak UI is a good program though.
  3. knuck
    25 Jan 2002
    BUMP !
    okay this thread had only one reply but I still believe it's a good idea that could be very interesting if you guys got into it :D
  4. notatoad
    notatoad pretty fing wonderful
    25 Jun 2004
    recycle bin > properties> uncheck "display confirmation dialog on delete" works on xp, vista, and 7.
    i keep putty shortcuts to my fileserver and my school's server in my quicklaunch toolbar with the username and password already entered.
  5. Silver51
    Silver51 I cast flare!
    24 Jul 2006
    Well, I posted this in another thread some time ago, but I guess it might be useful if you're still using XP.
    Windows XP
    There were a series of tweaks that we applied to our older laptops at work. They're not 'extreme' tweaks, so don't break or disable anything. (I know 1&2 are the same, but it's how I've always done things.)
    General
    1. Disable the Indexing service on the hard drives
    a. Click on My Computer
    b. Right click on C: drive and select Properties
    c. Uncheck the Allow Indexing Service box and press Apply. Press Ignore for any protected Windows files the service can’t un-index.
    2. Remove the 'Indexing Service' from the Control Panel, Add/Remove Programs, Add/Remove Windows Components
    3. Check that the IDE drives are set to DMA mode and not PIO
    a. Right click on My Computer
    b. Select Properties
    c. Select the Hardware tab then click on Device Manager
    d. Expand the IDE ATA/ATAPI controllers tree
    e. Select the Primary IDE channel
    f. Click on the advanced settings tab and set both Transfer Modes to DMA
    g. Repeat stage f for the Secondary IDE channel
    REGISTRY
    Messing about in the registry can damage your operating system.
    If you are in any way unsure about editing the registry, then don't do it and
    skip to 6
    4. Speed up network browsing by preventing windows checking for scheduled tasks on other networked computers
    a. Open up regedit
    b. Navigate to
    HKEY_LOCAL_MACHINE/Software/Microsoft/Windows/Current Version/Explorer/RemoteComputer/NameSpace
    c. Find a key named {D6277990-4C6A-11CF-8D87-00AA0060F5BF}
    d. Right click on it and delete it
    5. Disable NTFS file timestamp
    a. Open up regedit
    b. Navigate to
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\FileSystem
    c. Create (or edit) a new DWORD entry called: NtfsDisableLastAccessUpdate
    d. Set the DWORD value to 1
    Finally
    6. Run Disk Cleanup and Disk Defragmenter
    * If you don't mind losing the blue Luna theme, changing the desktop theme to Classic saves about 10mb memory.
    *. Change the XP theme
    a. Right click on the desktop
    b. Select Properties form the menu
    c. Under the Themes tab, select Windows Classic
    d. Click Apply
  6. Silver51
    24 Jul 2006
    Tweaks for running a solid state drive with Windows Vista. A lot of these are tidied instructions from other places (I forget where,) that were gathered after getting an SSD for use as a primary drive with Vista x64.
    Tweaks for Running a Solid State Drive under Vista
    Disable
    Auto Defrag, Indexing, Write Caching, Short File Names, NTFS Timestamp.
    Vista Automatic Defrag
    1. Click Start
    2. Click Control Panel
    3. Select the Control Panel Home
    4. Click System and Maintenance
    5. Under the Administrative Tools section at the bottom, click Defragment your hard drive
    6. Click or unclick Run automatically (recommended) depending if you want this feature enabled or disabled.
    7. Click OK
    Remove Indexing
    1. Go to, Start (blue marble) > Computer
    2. Right click on your drive and select 'properties'
    2. Uncheck 'index this drive for faster searching'
    Disable Write Caching
    1. From the Device Manager expand the disk drives category
    2. Right click your drive. Select 'Properties' from the menu then click on the 'Policies' tab
    3. Uncheck 'Enable write caching on the disk'
    Disable Short File Names
    The run command:
    fsutil behavior set disable8dot3 1
    Note that the Windows XP environment variables %TEMP% and %TMP% typically use short names. Program installations sometimes use these variables If this change causes trouble and you need to restore the short name function, the command is; fsutil behavior set disable8dot3 0
    Disable Timestamp for Last Access
    The run command:
    fsutil behavior set disablelastaccess 1
    Note that some backup programs may need this information. If you wish to restore the timestamp, the command is; fsutil behavior set disablelastaccess 0
