Scratch Build – In Progress Project Espada
Discussion in 'Project Logs' started by Zesti, 6 Jun 2013.
  1. Zesti
    Zesti Aluminium + file
    9 Feb 2010
    Project Index
    000 - Start of project
    001 - More chassis parts cut + finished motherboard tray
    002 - Micro-update: Black RAM
    003 - Sanded chassis components + chassis test fit
    004 - More chassis photos + thoughts about the theme and other things
    Hi everyone!
    After a long pause, I'm back with new worklog. This time it's going to be HTPC/Steambox, but I wanted something more original than your usual HTPC case. Hence I'm going to build it completely from scratch using only hand tools - Jigsaw will be the highest tech tool for this build. Material is mainly 3mm aluminium, but there might be some acrylic too for light effects.
    Components are pretty basic for this project - Mini-itx board with some fast memory and an APU. Plus Noctua cooler and Intel SSD. Oh, and 150W PicoPSU too.
    I gathered these parts over a long period of time so photos are a bit random.. :D But let's start with the APU:
    If someone is wondering why I'm using 5800K and not the newer 6800K, it's because I bought this CPU several months ago. In fact the system has been in use for a while, but just without the case.. :brrr:
    Here's the CPU cooler I'm using. I think it's not recommended for 100W TDP processors, but seems to work just fine since I've disabled turbo and undervolted 5800K quite bit. :)
    And by the way, this is my first Noctua cooler ever! Pretty cool packaging too, huh?
    It's a bit hard to see, but this cooler does have a couple heatpipes:
    Rest of the components:
    Components installed:
    And yeah, I removed heatspreaders from the memory.. Orange color doesn't fit to this project and it was rather tight fit between the cooler and the PicoPSU.
    Random beauty shot..
    And system running:
    Everything is working just fine.. Surprisingly fluid too, seems like APU+SSD+W8 is pretty nice combo.
    And now onto the good part!
    I started building with this easy part. Bending it was the hardest thing to do.. I don't have any fancy metal bending machine so I used a couple aluminium plates and hands instead. :lol:
    Luckily this is the only part that needs bending in this project..
    Next I started to cut sidepanels. Drawing is printed on paper which is then glued to the aluminium.
    Looks pretty good..
    After a while I had another sidepanel too and I couldn't help myself.. I just had to make a quick test fit to see how it looks. :)
    And yes, it should become a computer case and not a spaceship. :hehe:
    More soon.. :dremel:
    Pranja likes this.
  2. Pranja
    Pranja Blackwolf
    18 Dec 2011
    This will be awesome project. I can allready see that. :)
    And yes, it looks like Normandy. :p
  3. Azariel
    Azariel Minimodder
    23 Oct 2008
    Very nice start! Looking forward to see how this will unfold!
  4. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    Looks very interesting. I´ll be watching
  5. Cheapskate
    13 May 2007
    Quoted for bad pun. Fantastic start.:D
  6. Zesti
    9 Feb 2010
    Thanks guys! :thumb:
    Just some misc photos of the progress. :)
    Printed drawings:
    Rough cut parts:
    Motherboard tray sanded and ready to be painted. Now I just need to sand rest of the parts..
  7. sixfootsideburns
    sixfootsideburns modeteer
    6 Feb 2009
    thats shweet.
  8. Trance
    Trance Two steps forward, one step back
    6 May 2009
    What is this witchcraft! Wish I could run fans with magic too! would save on electricity.
    Also looking awesome, keep up the good work, love the efficient yet sleek design!
  9. Evenge
    Evenge Minimodder
    16 Sep 2006
    Oh yeah! Another one from you! :thumb: Wish i could file as smooth edges as you do. Looks like I still have much to learn. :duh:
  10. sixfootsideburns
    6 Feb 2009
    If by magic you mean blowing into the fan to make it spin, then I'll bet your pretty damn magical too! Albeit pretty light headed if your trying to cool your PC that way :lol:
    That was my first guess as to how he did it at least lol
  11. Zesti
    9 Feb 2010
    Thanks mate! :)
    :hehe: It's just Noctua's new wireless fan technology.. Cable in the photo is just optional for older systems.
    :worried:
  12. lobster_johnson
    lobster_johnson Fear the Claw of Justice!
    30 Sep 2008
    This is fantastic so far! I love the shape of the motherboard tray.
    Can't wait to see this come together!
  13. Zesti
    9 Feb 2010
    Thanks!
    Just some fine tuning of components.. After removing heatspreaders from the memory, brown sides of the PCB's really started to bother me. :D Little bit work with marker made them look much better:
  14. sixfootsideburns
    6 Feb 2009
    its the small details that make or break it mate, nice touch with the black edges
  15. Meelobee
    Meelobee What's a Dremel?
    5 Nov 2003
    Buildlogs like this make me want to have 2 things. Crazy mod skills and a better cam..
    Awesome work so far, the finish on the alu is amazing :)
  16. Zesti
    9 Feb 2010
    sixfootsideburns, couldn't agree more. :)
    Meelobee, thanks! Your modding skills seem fine to me and good cameras are cheaper than ever.. :D
    Sanding these parts took forever..
    :dremel:
  17. Ozel
    Ozel What's a Dremel?
    15 Jan 2013
    Looks really smooth so far..
    Amazing work :thumb:
  18. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    A lot of talent, great ideas, and Cheaps' approval? I'm in. :thumb:
  19. Meelobee
    5 Nov 2003
    lol @ 'No Step'
    Amazing finish on the alu :)
  20. LegendaryScott
    LegendaryScott Trying to live up to the name
    5 Apr 2013
    Simply awesome.
    Cant wait to see more
