Scratch Build – In Progress MATX air cooled gaming rig - 13-July-2015 complete
Discussion in 'Project Logs' started by Waynio, 5 Jul 2015.
  1. Waynio
    Waynio Relaxing
    20 Aug 2009
    New project time, it's a MATX air cooled gaming rig, open chassis with carrying handle, really easy maintanance, hopefully I've put enough thought into it all holding together well. :D
    Just getting the pieces made before I start bending/curving, assembling, doing a little each day on it.
    More soon.
  2. Icelander
    Icelander Minimodder
    3 Mar 2015
    wow. This will be fun to watch
  3. B NEGATIVE
    B NEGATIVE All Hail Kim Jong Magoo!
    8 Aug 2011
  4. Teelzebub
    27 Nov 2009
    Great start, subed
    Your workshop looks just like my basement :worried:
  5. Waynio
    Waynio Relaxing
    20 Aug 2009
    Thanks, cellar room that was going to waste as a storage (hoarding) room, cleaned it up & added work tops, nice having a dedicated space to mod in. :)
    I'll try to post progress every time I reply to keep it a productive log.
    Cut, drilled, tapped & added m3 brass inserts to the back IO expansion piece, made from 10mm acrylic.
    Mounted to the back panel.
    Mobo panel added.
    Saving the curve cuts for when I have the curved pieces done to increase chance of lining up correctly.
  6. Teelzebub
    27 Nov 2009
    I used to use my basement as the work shop now it's just for the heavy tools like the bench saw etc,
    I ended up taking a wall out between the two upstairs front rooms and converting that into one big workroom, It annoys the A'holes next doors a lot more now lol
    Anyway nice going it's really coming along
  7. Cheapskate
    13 May 2007
    Sweeeeeeet.:D Are you half- finished already?
  8. storm-83
    storm-83 Minimodder
    7 Nov 2014
    isn't the non-centered position of the handle going to bring the case off-balance when lifted?
    otherwise, looking good, and looking forward to following the progress!
  9. Waynio
    Waynio Relaxing
    20 Aug 2009
    Could do with adding some colour to make it a less miserable room to mod in but an mp3 player & headphones mostly sorts the gloom effect. :D
    My neighbors are nice luckily so I keep any noisy work for during the day.
    Yeah it's coming along faster than I thought it would. :D
    Possibly, it's definitely speeding along, even more so with my self imposed rule of make some progress whenever I reply. :lol:
    I think it will be fine but don't know for sure, will do soon enough though. :D
    Thanks.
    Curved & bent the PSU cover, front panel is just resting in place.
  10. Cheapskate
    13 May 2007
    Yep! -Half done.:lol:
    Last pic: lotion bottle shadow. You really DO enjoy your work!
    -Joking, I know it's the saw head.
  11. Waynio
    Waynio Relaxing
    20 Aug 2009
    :lol: Actually the shadow is of the curve bender handle.
    To be honest I don't know how complete this is, still very early days on it.
    Load of drilling & tapping for mounting the 33mm acrylic support blocks.[​IMG]
    And added 10mm acrylic psu cover supports.
  12. Waynio
    Waynio Relaxing
    20 Aug 2009
    Fully mounted the psu cover supports & added the side panel.
    Next I'll mount & curve the front panel.
  13. Waynio
    Waynio Relaxing
    20 Aug 2009
    Late session went on the custom fan mount.
  14. Icelander
    3 Mar 2015
    :clap:OMG those Fan holders are from another Level of modding :hip:
  15. Teelzebub
    27 Nov 2009
    That's some nice cutting there mate, they look brilliant
  16. Cheapskate
    13 May 2007
    Coming along nicely.:D
  17. bulldogjeff
    2 Mar 2010
    Wooooow this is off to a flier. I missed it totally. looking good mate. I love the fans set up on the front.
  18. Waynio
    Waynio Relaxing
    20 Aug 2009
    Thanks guys, been pushing along again today. :dremel:
    Got it close to the design curve but it's a good job I saved the cut until the curve was done.
    How it's all looking now.
  19. bulldogjeff
    2 Mar 2010
    Very nice mate..
    I think I need to get a scroll saw. I could have hours of fun destroying lumps of metal :D
  20. Waynio
    Waynio Relaxing
    20 Aug 2009
    Thanks Jeff.
    Defintiely a nice tool to have, even the cheap one that broke due to misuse was good while it lasted.
