Peripherals O rings
Discussion in 'Hardware' started by b1g-d0g, 1 Mar 2017.
  1. b1g-d0g
    b1g-d0g Multimodder
    30 Sep 2001
    Hi I've got a corsair K65 RGB Keyboard with speed mx's and I'm thinking of buying some clear o rings off the bay is this a good idea.
    Thanks.
  2. David
    7 Apr 2009
    No, it's a dreadful idea, IMO.
    O rings do their best to make your lovely mech board feel like a £5 rubber dome PoS.
    If you absolutely must try them out, ping me your address - I'm fairly sure I still have a bag or two gathering dust. In my honest opinion, they aren't worth the time it takes to fit them but I only discovered that by trying it for myself.
  3. GeorgeK
    18 Sep 2010
    It's a horrific idea - makes a lovely mechanical board feel like a cheap nasty membrane board... Why are you thinking of buying them?
    Edit: ^Haha - seems that we're in agreement :) For some reason your reply wasn't showing when I typed mine even though they're 15 minutes apart :p
  4. Guest-56605
    Guest-56605 Guest
    :eeek: :eeek: :eeek: NOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO Don't do it!!! :eeek: :eeek: :eeek:
    The mere suggestion is horrific :jawdrop:
  5. David
    7 Apr 2009
    You probably have the same bad habit as me - click on new posts and then open any interesting threads in their own tabs, and by the time you get around to one of the later ones, there could well be several replies that you are unaware of.
  6. Nexxo
    23 Oct 2001
  7. spolsh
    spolsh Multimodder
    4 Feb 2012
    If it's too loud for you when typing , go for it, else, naaah.
    Mech's really do feel less good with the o-rings on, but they are quieter too.
  8. dalton12
    dalton12 What's a Dremel?
    7 Apr 2016
    Putting old mouse mats under the kb will reduce sound slightly.
  9. b1g-d0g
    b1g-d0g Multimodder
    30 Sep 2001
    Ok I'll not get them :) it's my first mech board had a old Microsoft keyboard for the last 5 years,so it's still strange to me at the moment.
