Graphics 8800GTX SLi for BF3?
Discussion in 'Hardware' started by keir, 11 Dec 2011.
  1. keir
    keir S p i t F i r e
    5 Oct 2003
    Right now I run a single 8800 GTX for BF3 on a mix of high/medium @ 1920x1080 with no issues.
    would it be worth going for a 2nd 8800GTX?
  2. Blogins
    Blogins Panda have Guns
    3 Aug 2010
    Probably not worth the power usage to be honest. A single GTX 460 would trump two 8800 GTX SLI all day long.
  3. murraynt
    murraynt Modder
    6 Jun 2009
    +1 or even a 4890/275GTX
  4. keir
    5 Oct 2003
    right but can you get a 460 for under £50
  5. LeMaltor
    LeMaltor >^_^
    3 Oct 2003
    If there are no issues then why bother?
  6. murraynt
    murraynt Modder
    6 Jun 2009
    No, But you could get a 280 for that. :rock:
  7. Blogins
    3 Aug 2010
  8. mucgoo
    mucgoo Minimodder
    9 Dec 2010
    Your probably better of selling your 8800 and buying a new card mainly due to how overpriced they are second hand. You'd think they should be around the £10+ postage mark by now.
  9. chewbaccas_nan
    chewbaccas_nan Minimodder
    27 Jun 2011
    High to medium settings on full HD? I'm struggling on low settings on 1400x900 lol with my 8800
  10. keir
    5 Oct 2003
    I think I'll just leave it then.
    Is it GTX and what clock settings are you on?
  11. rob the bank
    rob the bank What's a Dremel?
    13 Mar 2010
    Must admit from all the graphics cards we used over the last 7 years, the 8800GTX was the one that had the highest number or warranty returns, over 50% of the systems we built with a 3-year warranty had the GTX fail in the 2nd or 3rd year, so I wouldn't risk buying a 2nd hand 88GTX card, that’s if you can find a pair that still work.
    Wait till it dies and then buy a GTX 460 / 560.
  12. Dwarfer
    Dwarfer What's a Dremel?
    30 Mar 2011
    FYI The latest patch for BF3 has made a performance hit on a number of machines. I'd wait until they bring out a fix for this (hopefully in the next patch)
  13. chewbaccas_nan
    27 Jun 2011
    Mines just a GT model, but its been factory overclocked by BFG Tech.
