Blogs How to enable Windows 7 God Mode
Discussion in 'Article Discussion' started by Cutter McJ1b, 8 Jan 2010.
  1. Cutter McJ1b
    Cutter McJ1b Home-cut jibs at discount Prices
    18 Feb 2009
  2. wyx087
    15 Aug 2007
    lol, saw that on OCn, i think it's just a hidden folder in windows search index for start menu quick searches.
    therefore i don't see the point in creating such a folder, much easier to just do: Win key --> type the stuff you want.
  3. oMonarca
    oMonarca Elitist Brick
    15 Dec 2009
    Unless you don't know what stuff you want, then knowing all the options available might be helpful.
  4. Krikkit
    21 Jan 2003
    Or if you're just setting up someone's computer for the first time - instead of having to monkey up and down the masses of control panel categories.
  5. cybergenics
    cybergenics What's a Dremel?
    27 Jun 2009
    In case anyone is stupid enought to try it on Vista 64, don't, as when I staggered in drunk the other night, saw this on CNet and thought I would try it, whilst not reading the bit about it crashing Vista 64.
    What basically happened (or happened) is as soon as you rename the folder, all the icons on your desktop start flashing and basically the computer becomes inoperable. You can still shut it down though. It also exhibits the same behaviour in safe mode, and you can't access system restore through startup (recovery) to fix it !
    But it works fine on my Win 7 64bit lappy !
  6. Omnituens
    Omnituens What's a Dremel?
    5 Apr 2006
    So giving this a try when I get home.
  7. Er-El
    Er-El Minimodder
    31 May 2008
    Still on the first step to grow a big white beard.
  8. mjm25
    mjm25 What's a Dremel?
    19 Jan 2009
    i've got a mess of needing-to-be-trimmed beardage... therefore i declare myself Godly, WOOF! i shall give this a go.
    P.S. I'm loving your blog section, especially when you guys revealed Ninite to me a few weeks back <3
  9. Blackie Chan
    Blackie Chan What's a Dremel?
    5 Nov 2009
    OMG this is so cool. Thank you.
  10. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
  11. thehippoz
    19 Dec 2008
    lol just rd it in cmd prompt :D
  12. leslie
    leslie Just me!
    19 May 2009
    Godmode?
    It's just a different way of viewing control panel (with fewer options).
  13. Omnituens
    5 Apr 2006
    yeah, it doesn't actually give you more options. Just different way of accessing them.
  14. Blackie Chan
    5 Nov 2009
    The different way of accessing them is by not going through context menus hidden throughout the OS. I think this should be a standard!
  15. hurgh
    hurgh What's a Dremel?
    11 Jan 2010
    Just a note, there is also a few more of these:
    Code:
    Test1.{00C6D95F-329C-409a-81D7-C46C66EA7F33}
    Test2.{0142e4d0-fb7a-11dc-ba4a-000ffe7ab428}
    Test3.{025A5937-A6BE-4686-A844-36FE4BEC8B6D}
    Test4.{05d7b0f4-2121-4eff-bf6b-ed3f69b894d9}
    Test5.{1206F5F1-0569-412C-8FEC-3204630DFB70}
    Test6.{15eae92e-f17a-4431-9f28-805e482dafd4}
    Test7.{17cd9488-1228-4b2f-88ce-4298e93e0966}
    Test8.{1D2680C9-0E2A-469d-B787-065558BC7D43}
    Test9.{1FA9085F-25A2-489B-85D4-86326EEDCD87}
    Test10.{208D2C60-3AEA-1069-A2D7-08002B30309D}
    Test11.{20D04FE0-3AEA-1069-A2D8-08002B30309D}
    Test12.{2227A280-3AEA-1069-A2DE-08002B30309D}
    Test13.{241D7C96-F8BF-4F85-B01F-E2B043341A4B}
    Test14.{4026492F-2F69-46B8-B9BF-5654FC07E423}
    Test15.{78F3955E-3B90-4184-BD14-5397C15F1EFC}
    GodMode.{ED7BA470-8E54-465E-825C-99712043E01C}
    The folder name can be changed by changing the text before the "."
    -Hurgh-
  16. Pookeyhead
    30 Jan 2004
    Working fine here in 64bit :)
  17. cdb
    cdb No comment
    25 Apr 2009
    Can't use that folder name in my win7 64bit. It doesn't like the symbols.
  18. knuck
    knuck Hate your face
    25 Jan 2002
    what I would like is a way to sort the icons in the control panel vertically instead of horizontally. This pisses me off because every time I search for something it takes me 10times longer than usual because things aren't at the same place depending on the size of the window
    argggggg
  19. knuck
    25 Jan 2002
    I am bumping this thread in hope someone has an answer to my question from the post above. I will only bump it once though :)
  20. M7ck
    M7ck Ⓜod Ⓜaster
    28 Mar 2009
    Cant you just change the view mode to small or large icons? It wont change it to a vertical layout but it will keep them all listed in alphabetical order enableing you to find things quicker.
Tags: Add Tags
