Other C# Function
Discussion in 'Software' started by Comfyasabadger, 18 Jul 2012.
  1. Comfyasabadger
    Comfyasabadger What's a Dremel?
    23 Jun 2009
    Does anyone know if it's possible to loop through the parameters of a function and return the object type and in the instance of say int and string the object value?
    Code:
    xlSheet.Row CreateContentRow(int index, string user, string limit, string card)
            string[] headerColumns = new string[] { "A", "B", "C" };
            //Create the new row.
            xlSheet.Row r = new xlSheet.Row();
            r.RowIndex = (UInt32)index;
            [B]xlSheet.Cell firstCell = CreateTextCell(headerColumns[0], user, index);
            xlSheet.Cell secondCell = CreateTextCell(headerColumns[1], limit, index);
            xlSheet.Cell thirdCell = CreateTextCell(headerColumns[2], card, index);
            r.AppendChild(firstCell);
            r.AppendChild(secondCell);
            r.AppendChild(thirdCell);[/B]
            return r;
    FunctionObjects(CreateContentRow)
    foreach(object obj in CreateContentRow.Objects)
    if(obj.type == string)
    string test = obj.value;
    Was just wondering whether it was possible to compress the 6 bold lines into 2?
  2. tehBoris
    tehBoris What's a Dremel?
    30 Jan 2011
    stick em in an array and iterate over the array would be the way to avoid code duplication.
  3. Comfyasabadger
    23 Jun 2009
    Thanks.
    Code:
    string[,] headerColumns = new string[,] { { "A", "B", "C" }, { user, limit, card } };
            //Loop to add each element to a cell
            for (int i = 0; i <= 2; i++)
                xlSheet.Cell inputCell = CreateTextCell(headerColumns[0, i], headerColumns[1, i], index);
                r.AppendChild(inputCell);
            return r;
