News Netbook graphics given a boost
Discussion in 'Article Discussion' started by CardJoe, 30 Apr 2009.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. Gunsmith
    Gunsmith Maximum Win
    23 Sep 2005
    requires .net 2.0
    theres got to be a more eficient way of hacking clock speed then installing .net
  3. Saivert
    Saivert Minimodder
    26 Mar 2005
    Just install it. There are lots of apps that are developed using .NET framework today. It's a more managed secure way to make programs. They tend to be more reliable.
    It's only Windows XP that doesn't come bundled with it. Even ATI Catalyst Control Center requires .NET Framework 2.0 to install and run.
  4. Headspark
    Headspark Minimodder
    23 Feb 2005
    works great for me!!
    more wow at work :p
  5. AstralWanderer
    AstralWanderer What's a Dremel?
    17 Apr 2009
    You do know that .NET Framework adds over 1.2MB of data to the Windows Registry, right? (a 12% increase compared to a new Windows install). Since registry size affects startup time (it has to be loaded into memory) and memory usage, keeping "registry bloat" under control is a key factor in maintaining a tidy (and stable) Windows installation.
    As for Catalyst Control Centre, that is not only the most inappropriate example of .NET usage I have seen, but also excellent marketing for ATI Tray Tools - or Nvidia Forceware. :rolleyes:
  6. DirtyH
    DirtyH What's a Dremel?
    20 Jan 2005
    oh my god, 1.2MB...
    we're all going to die
  7. steveo_mcg
    steveo_mcg What's a Dremel?
    26 May 2005
    And what of the rest of the .net frame work, if your working with an 8gb disk every little helps.
  8. zimbloggy
    zimbloggy Genius Extraordinaire
    8 Jul 2008
    I used to have the 945G chipset on my desktop (well, I still do, but I got a decent graphics card). There were some people who modded the 965 (a better intel integrated chipset) to get better framerates and compatibility.
    If you have a netbook with these chipsets this group would probably help you: http://groups.google.com/group/intel9x-gaming?pli=1, but it's mainly for XP and Vista users.
  9. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    yeah the writer of that program is on the msiwind forums.. these guys use setfsb and that gmabooster to oc their netbooks to hell XD some up to 2.1ghz and claim youtube 720p video runs without issues- I dunno seems aweful high without stability issues
    this little mini pci device looks cool http://shop.ebay.co.uk/items/_W0QQL...b=&_trksid=m270.l1313&_odkw=pcie+hd&_osacat=0
    would replace your wifi card though.. but this in a cheap netbook, just use the wired lan and setfsb for the youtube.. I dunno call me crazy but > nvidia ion?
  10. Clo_UD
    Clo_UD What's a Dremel?
    30 Apr 2009
    Wow, I'm very interested. I just found 3D Mark charts with GMABooster enabled and without it. http://www.hardware.info/images/news/gmabooster_screenshots_550.png
    Twice faster pixel shader rendering! Twice faster texture processing! To good to be true... Though this is a well-known german site and I doubt they have been kidding or lying :)
    The question is: why has Intel degraded GMA 950 on netbooks? Is it a commercial trick to make netbooks incomparable to even low-end laptops?
  11. wyx087
    15 Aug 2007
    if no voltage change yet increase clock speed by more than 200%, surely that would introduce instability?
  12. Turbotab
    Turbotab I don't touch type, I tard type
    4 Feb 2009
    Did those guys running @ > 2 GHz, post any temp readings?
  13. 500mph
    500mph The Right man in the Wrong place
    22 Jun 2007
    Battery life, that is all.
  14. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    Astral... are you serious?
    You don't install .NET because it slows down your boot times? And, no offence, but I wouldn't call .NET registry bloat as it actually brings you some nice additions and support for a lot of programs/tools you might find useful.
    Running Vista with .NET 3.0 [no SP1 installed yet, thanks to crappy mobile broadband being the most unstable thing since W95A] I can't see it being unstable at all, or booting too slow.
    Well, each to his/her own I guess...
  15. thehippoz
    19 Dec 2008
  16. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    I cant wait to get my EeePC 1000he, so this would also solve the Hulu issues as well I would assume?
    Edit: I installed it onto an EeePC 1000HA at work and bumped it up to 400 and so far all the hulu issues we were having with the lag at full screen and at 480p and what not is gone so this is great, we had two of these EeePC get returned for the sole reason that they couldnt handle Hulu correctly, I came up with some work arounds to get it working but this way with the booster its sooo much easier, so ya this is awesome. For the hell of it we are going to install WoW onto it, we did that before and in areas with no people we got up to 17fps and in heavy areas 1-2 fps so it will be interesting to see what the difference will be now probably not to much but ehh still should be fun.
  17. HourBeforeDawn
    26 Oct 2006
    huh you think that would work? could be something to consider if you dont need wifi like in a long car ride and wont have access to anything.
  18. AstralWanderer
    17 Apr 2009
    Boot times are not the overriding concern for me but maintaining a bloat-free system (as much as possible) is. While most other software adds to the Registry, such additions tend to be less than 30KB so if you consider 1.2MB the equivalent of installing more than 50-60 programs, then you have a reasonable idea of its impact.
    Fine, if there is something that you really value that requires .NET then install it. However it is an issue that deserves careful and critical consideration, not a "no-brainer" as one poster above seemed to suggest. And companies that require it for necessary system utilities (looking at you ATI) or install it without user consent (yes, Obsidian, that means you with NWN2) deserve criticism.
    Since the trademark of .NET software tends to be extremely slow load times (e.g. Stardock's Impulse initially took more than 10 seconds to start up on a well-specced system) I would always look for an non-.NET alternative that, to be frank, shows more consideration for user time.
    .NET's inclusion by default in Vista is likely to be one of several reasons for Vista's poorer performance and higher resource use compared to Win2K/XP.
  19. perplekks45
    9 May 2004
    Vista performs poor? Haven't noticed this for quite some time. Yes, it wasn't the fastest OS on the planet and it might be slower than XP/7 sometimes but overall it's quite fast [now].
    And higher resource use? You mean the SuperFetch and that stuff that "uses" your RAM? I thought we finally settled that discussion a long time ago. :p
    But I agree with you that it shouldn't be used for system utilities, especially given the download size of new versions and SPs and yes, it should be handled as a crime to install ANYTHING without user consent [listen carefully, Sony!].
  20. cyrilthefish
    cyrilthefish What's a Dremel?
    15 Apr 2004
    that was odd, tried it on my ultraportable and it actually made it slower when allegedly overclocked
    3dmark03:
    default: 687
    400mhz: 595
    :confused:
    might be a compatibility issue with windows7 tho
Tags: Add Tags
