Watercooling Water blocks for R9 290 cannot find any
Discussion in 'Hardware' started by flame696, 10 Mar 2016.
  1. flame696
    flame696 Terminating People Since 1980....
    15 May 2009
    Guys can you help me out, I am struggling to find any water blocks for a R9 290. It seems like the GPU blocks have vanished. I was looking for EK full water block preferably a Acetal/Copper but everything is nickel based. What has changed so much over the past year with water blocks
  2. Parge
    16 Jul 2010
    Nothing - its just an old card now. They only do limited production runs because they absolutely have to sell every piece.
  3. flame696
    15 May 2009
    but i thought the water blocks for the r9 290 fit the 8gb 390s
  4. Parge
    16 Jul 2010
    Could be the case, but then they'd move onto making them - could you buy a 390 block instead?
  5. flame696
    15 May 2009
    they are also out of stock
  6. Parge
    16 Jul 2010
    Getting to the end of the line I guess - second hand?
  7. flame696
    15 May 2009
    I have tried second with 2 forums and no one seems to have one ive tried ebay and still nothing i feel like just sell the r9 290 and getting one of the newer cards
  8. sandys
    sandys Multimodder
    26 Mar 2006
    I have 3 watercooled 290s which I am pulling out for to sell for my next build, so there may be some coolers on the market soon ;) :D
  9. Chris_Waddle
    Chris_Waddle Loving my new digital pinball machine
    26 Mar 2009
    Well I've looked on here and as you can see on this model (if you scroll to the bottom of the info) its compatible with a reference R290
    The full list of stock for you cards is on this list
    Hope that helps.
  10. flame696
    15 May 2009
    Thanks Chris but the prices are incredible.
    Sandys when will you be sticking them up for sale?
  11. jinq-sea
    15 Oct 2012
    I don't reckon that's too bad for a decent block, personally! It is in Euro too, remember.
    (Perhaps I'm just daft. I just imported a Titan X Hydro Copper block from the US)
  12. Chris_Waddle
    26 Mar 2009
    I also think £90 is a fair price for a quality waterblock, but if you can get hold of a 2nd hand one then you should make a good saving.
    I was also very tempted by the hydro copper blocks (I have 2 x EK Titan X's) and nearly bought those blocks - they didn't have any in stock at the time I ordered, so went for EK ones. Wish I'd bought these ones though. Best looking blocks I have seen. The amount of times I've nearly clicked buy even though I dont 'need' them.
  13. jinq-sea
    15 Oct 2012
    Man they're good looking blocks. I got obsessed with the HC block so had to have it! I've got an aquacomputer glass one for my original titan (this one I think) - I love those too!
  14. sandys
    sandys Multimodder
    26 Mar 2006
    I can't really say, it'll be the next free weekend I get to work on it, I just don't know when that is, I started the other day but life gets in the way.
    Those coolers above look good and that is the going rate for a new full cover block for most GPUs, my EK R290 FC blocks were £90 a piece.
  15. flame696
    15 May 2009
    I think im going yo get rid of this card and pick up a couple of 780s with water block snd back plates installed
  16. stephen0205
    stephen0205 MrSteve
    11 Mar 2016
    i had this problem close to a year ago getting a water block. Ended up getting a kraken g10 bracket and using an aio unit with the gelid enhancement kit.
    Not a solution for yourself maybe but, possibly worth a look
