Thought I'd make a friendly hello post on these forums. I've been meaning to get back into folding for a while but completely forgot all about it. I have since but the FAH program in my start menu so it launches automatically instead so I don't forget I'm still using the same configuration of computer, but I'm hoping within the next 3-4 months to add a PC cluster of 4-5 PCs (fx6300, 4gb ram) into the mixture folding alongside my existing setup Folding unfortunately has to be a low priority for me in terms of expenditure due to house bills/personal life but I like to think of it as every little helps The PC I'm using currently hosts a webserver, folding 24x7, virtual machines and a few other nifties. So the cluster I'm building will be used for clustered folding and clustered web hosting setup. I like my IT technologies so always into developing it Now that that's over, could anyone confirm if this is the right setup for SMP folding as it's been a while and I haven't used it as I'm sure the last time I used the FAP SMP client I had to enter FAHSMP -4 or something EDIT - Found it, should have been FAHSMP -SMP 4, I've been running in a single core mode like a dumb@ss
Thanks, also looking at purchasing new equipment next year. Mainly to develop IT skills. What's the ppd like of 1 x 3820 CPU vs 5 x 8320 AMD CPU. I'm looking into clustered web hosting so essentially it would be 40 cores vs 8 cores (with hyperthreading) but Intel seem to be better unless it's a 4P config I haven't decided fully on final config, but I'm spending possible £1500-2000 to include a new folding rig or cluster (not all the money on the setup, as I'm buying stuff like a new sound card, mic, server rack etc) the right itself will be around 800-900 I think
Been thinking with the money I was going to spend I may just buy 2 or 3 second hand i2700k PC's should not me 100+ ppd I think on linux and gives me machines to play around with clustering
Stanford changed everything all around again now? I know it used to be i2700k would get around 40k ppd on linux and would trump GPUs. Then standford changed the -bigadv config so you needed lots of cores or something. What's the best advice atm, should I go GPU setup?
A GTX660Ti will net 65k+PPD (for £200), more than any consumer CPU. To get -bigadv you will need twelve cores (and Linux), that is the only way to beat GPUs at the moment. Unless you are really serious about Folding full-time I'd just buy a nice computer and Fold on it in my off time.
Thanks, I'm no 100% into folding, it's just something I'd like to donate. If I had the money I'd do it, but I can't justify spending 10,000 on a few rigs just to fold with I'll definately be built some cheap PC's though mainly for IT stuff. I don't net much ppd on this rig, but every little helps
