I've just fitted a couple of new peripherals and have now run out of molex connectors. I've been searching online for the last hour or so for a similar cable to the one that came with my psu. It's an inline 6pin pcie to about 3 female molex connectors. (the ones with the tubes not the pins) Can you get these anywhere? I don't know the correct name, so maybe that/s why I can't find one. Failing that how can I get more female connectors in my case? TIA.
That would maybe do, but it would add more power draw onto the one cable I have. I'd prefer to get another cable that can start in a fresh 6 pin socket on my psu.
What make and model PSU have you got. If it's one of the more common ones additional cables are usually easy to get hold of
The power that thing is chucking out it would be pretty hard to overload it. You can always email OCZ and as them about getting more molex cables You will probably find they are pretty universal so making some is another option or getting some from another OCZ PSU
This looks like the cable I have. It starts off as a 6 pin plugged into the psu then has either 3 or 4 of those connectors on it.
What can you possibly have in your case that has used up all the molex connectors that would come with a 1000W PSU? Without knowing the exact pinout of the connector at the PSU end, we couldn't really guarantee any non-OCZ cable. It may look just like a 6 pin PCI-E but there's a good chance the pinout config isn't the same (it's not anyway as PCI-E is only 12V where as molex has 5 and 3.3V), and might not be the same as other PSU cables that also use 6 pin plugs to connect to the PSU.
It didn't come with that many, but........ PCIE usb3 card. Sata to sata slim adapter, something on my new usb3 card reader and maybe something else I've forgotten.
I know that's the molex connector. I was just trying to show the style of cable, even though it only shows a little bit of it. It's a modular 6 pin connector on the other end.
Ah so was it a 2nd hand PSU that only came with one molex cable? Also, won't a SATA to SATA slim adapter use a SATA power connector not a molex? Those first ones that bulldogjeff would be fine, you're not going to be drawing massive power from various misc expansion cards like that so all on one cable would be fine. *EDIT* Corsair cables won't work, the pin shapes are different, so that's one that can be scratched off. Neither will Seasonic, EVGA, Silverstone, Antec or BeQuiet.
No, it was brand new, It only came with the one cable with about 3 or 4 molex on it, but lots of other cables that don't have molex on them. The sata slim adapter used a molex for whatever reason. And OK on the third. (but I'd still prefer another cable if possible)
That newegg link says it comes with 3 peripheral cables. Quick ebay brings up these, in America, but only ones I can find. Molex and FDD cable SATA cable possibly use this with some SATA to molex adapters?
Why not just buy some molex connectors and swap the with the spare sata ones or get some sata to molex adapters and do it that way
Ah damn, I knew that, honestly, , for some reason saw 3.3V mentioned somewhere on the net while googling and fingers took over,
